problem with episode feature
chimeguy
#1 Post by chimeguy » Sun Nov 22, 2009 10:46 pm
I have some epsidoes x files that all have worked fine till the end last 2 dics I am getting this
MakeMKV v1.4.8 beta win(x86-release) started
Opening files on harddrive at H:/x_files_not_done/x files season 9/XFILES_S9_D6/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Title #0 with special attributes was skipped
Title #1 with special attributes was skipped
Title #2 with special attributes was skipped
Title #3 with special attributes was skipped
Title #4 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Opening files on harddrive at H:/x_files_not_done/x files season 9/XFILES_S9_D7/VIDEO_TS/
Title #1 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Opening files on harddrive at H:/x_files_not_done/x files season 9/XFILES_S9_D6/Customize/XFILES_S9_D6/VIDEO_TS/
another program DVD fab and nero do see the files in this episode and even can cut the files up into episodes( my west dig hdtv will not give chapters or play episodes)
Re: problem with episode feature
#2 Post by mike admin » Tue Nov 24, 2009 8:37 am
This should be corrected in a next version, 1.4.9
