#3481 Post by MartyMcNuts » Tue Jan 20, 2026 4:38 am
B12ian wrote: Tue Jan 20, 2026 4:33 am Yeah you’re right.
I flashed the driver with Terminal (macOS) successfully but the firmware didn’t update. Doh, I have a newer version (1.18.2) makeMKV.
Any idea when I can flash it? No rush.
Have a good day
Did you use enc in your command?
nicholfd
#3482 Post by nicholfd » Tue Jan 20, 2026 4:50 am
Have a good day
You can flash it now, even with current MakeMKV - just gotta get the command line correct... And no disc in the drive during flash. Then power cycle (remove all connections to USB drive) after flash.
B12ian
#3483 Post by B12ian » Tue Jan 20, 2026 5:04 am
Enc?
I followed the instruction for macOS.
Ah okay, I will try that tomorrow. If I have a problem , could I paste the terminal here?
Thamks
nicholfd
#3484 Post by nicholfd » Tue Jan 20, 2026 2:52 pm
B12ian wrote: Tue Jan 20, 2026 5:04 am Enc?
Thamks
"enc" refers to the command line option for encryption. It's required if the drive has encrypted firmware on it. This is not specific to macOS.
You could also use UTM or a trial version of Parallels, install an unlicensed Windows (Microsoft allows this for so many days) & flash using the SDFtool.exe, on macOS.
Thanks,
Frank
B12ian
#3485 Post by B12ian » Tue Jan 20, 2026 5:52 pm
Hello
I used the enc command and flashed the BD-RE BU40N into 1.03 using this command
./makemkvcon f -d '/IOBDServices/22DCDDE3' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
OS device name: /dev/rdisk6
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOBP6IF0044
Highest AACS version: 82
Firmware version: 1.03
I tested it with DVD, BLURAY and they work.
Can’t read UHD BLURAY.
Downloading latest HK to /Users/bxxxxx/Library/MakeMKV ...
Saved AACS dump file as /Users/bxxxx/Library/MakeMKV/MKB20_v77_A_Nightmare_on_Elm_Street_410F.tgz
Not my UHD ripper but I’m so curious why it’s happening.
Thanks y’all for pointing me to a right direction
justlovemovies
#3486 Post by justlovemovies » Tue Jan 20, 2026 6:52 pm
Coopervid wrote: Thu Jan 15, 2026 2:46 pm PM sent.
Thanks a ton! Got both of my drives flashed and working over the weekend. Took less than 5 min for both
nicholfd
#3487 Post by nicholfd » Wed Jan 21, 2026 1:45 am
B12ian wrote: Tue Jan 20, 2026 5:52 pm Hello
Revision: 1.03
I'm not sure where your firmware came from. This is the firmware I use, from the "All you need..." firmware download:
DE_LG_BU40N_1.03_MK.bin
This firmware works for me & 4K/UHD discs.
Note that I flashed "DE_LG_BU40N_1.03_MK.bin" using the SDFtool.exe in a Windows 11 VM (see my previous reply).
MakeMKV disc info with a 4K/UHD disc, that is rippable:
[b]Disc Information[/b]
Label: SPIDER_MAN_ACROSS_SPIDER_VERSE
Timestamp: 2023-07-13 15:43:25
Protection: AACS2.0/C v77
Data capacity: 81.32 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Ps. Be sure you've disconnected/power cycled the drive, after flashing.
Thanks,
Frank
#3488 Post by MartyMcNuts » Wed Jan 21, 2026 2:25 am
nicholfd wrote: Wed Jan 21, 2026 1:45 am
Revision: 1.03
Number of layers: 3
Thanks,
Frank
It's the same firmware. He just used the one in the original MakeMKV firmware pack. Mine are named better for easier reading as it's much easier to read DE_LG_BU40N_1.03_MK than HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934
B12ian
#3489 Post by B12ian » Wed Jan 21, 2026 4:12 am
MartyMcNuts wrote: Wed Jan 21, 2026 2:25 am
Revision: 1.03
Number of layers: 3
Thanks,
Frank
I tried Win11+SDFtool, same error-can’t decrypt a disc (WB). BU40N is from Germany, any difference with FW?
I’ll try another disc tomorrow
dialogueravenous
#3490 Post by dialogueravenous » Wed Jan 21, 2026 4:17 am
Is the "Silverstone TS14 slimsata 9.5mm to USB-Marty" the same as this? Says SST-TS14, then in the product photos it says "TS14B":
https://www.amazon.com/Silver-Stone-Opt ... B019OBKWBW
nicholfd
#3491 Post by nicholfd » Wed Jan 21, 2026 4:25 am
B12ian wrote: Wed Jan 21, 2026 4:12 am
Number of layers: 3
Thanks,
Frank
I've never heard of country/source of the drive mattering for firmware.
What is the Mfg/model of the USB drive you purchased, as sold retail? What was on the box? Are you sure it was a BU40N drive internally?
Do you have 2 x USB or 1 x USB + 1 x power connections to the drive? 4K/UHD require more power than audio/DVD/Blu-Ray. Single USB ports/connections typically cannot supply enough power to a drive for 4K/UHD.
nicholfd
#3492 Post by nicholfd » Wed Jan 21, 2026 4:31 am
dialogueravenous wrote: Wed Jan 21, 2026 4:17 am Is the "Silverstone TS14 slimsata 9.5mm to USB-Marty" the same as this? Says SST-TS14, then in the product photos it says "TS14B":
The Amazon link is an over-priced slim optical drive sized case for a SATA HD/SSD - look at the pictures from the 7th one on.
It will not hold a slim-line optical drive.
B12ian
#3493 Post by B12ian » Wed Jan 21, 2026 5:00 am
nicholfd wrote: Wed Jan 21, 2026 4:25 am
That’s it-more power to it.
My friend has the 43888 and he said he could rip 4K with one usb cable.
I bought 43888, hoping it would Pioneer but I lost the lottery-BU40N.
Thanks for reminding me about the power supply.
I’ll try that tomorrow.
Thank you again
#3494 Post by MartyMcNuts » Wed Jan 21, 2026 5:11 am
Yes, that is the same. It should include both the 9.5mm drive enclsoure and also a HDD rack to fit in a 9.5mm drive bay.
#3495 Post by MartyMcNuts » Wed Jan 21, 2026 5:17 am
B12ian wrote: Wed Jan 21, 2026 5:00 am
Thank you again
Your issue is not firmware related (unless using Linux). You have flashed the drive and the info looks fine. What happens when you insert a UHD disc? If the disc does not even show in MakeMKV,
1. Clean the disc.
2. Always insert the disc and let the OS initialise it first before you open up MakeMKV.
If you are using Linux, it is recommended to use firmware BU40N 1.00.
Also, it is best to use USB ports direct from the motherboard, USB-C if possible or use an AC self-powered USB hub of at least 24w. Do not use case ports for optical drives as they often have poor quality wiring and may not provide enough constant power.
Now, if you get an error or the disc won't decrypt, copy and paste the log window text.
