Did you use enc in your command?
You can flash it now, even with current MakeMKV - just gotta get the command line correct... And no disc in the drive during flash. Then power cycle (remove all connections to USB drive) after flash.
Enc?
I followed the instruction for macOS.
Ah okay, I will try that tomorrow. If I have a problem , could I paste the terminal here?
Thamks
Thamks
"enc" refers to the command line option for encryption. It's required if the drive has encrypted firmware on it. This is not specific to macOS.
You could also use UTM or a trial version of Parallels, install an unlicensed Windows (Microsoft allows this for so many days) & flash using the SDFtool.exe, on macOS.
Thanks,
Frank
Hello
I used the enc command and flashed the BD-RE BU40N into 1.03 using this command
OS device name: /dev/rdisk6
Product: BD-RE BU40N
Revision: 1.03
Serial number: MOBP6IF0044
Highest AACS version: 82
Firmware version: 1.03
I tested it with DVD, BLURAY and they work.
Can’t read UHD BLURAY.
Not my UHD ripper but I’m so curious why it’s happening.
Thanks y’all for pointing me to a right direction
./makemkvcon f -d '/IOBDServices/22DCDDE3' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.binOS device name: /dev/rdisk6
Revision: 1.03
.Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Downloading latest HK to /Users/bxxxxx/Library/MakeMKV ...
Saved AACS dump file as /Users/bxxxx/Library/MakeMKV/MKB20_v77_A_Nightmare_on_Elm_Street_410F.tgz
justlovemovies
I'm not sure where your firmware came from. This is the firmware I use, from the "All you need..." firmware download:B12ian wrote: ↑Tue Jan 20, 2026 5:52 pmHello
I used the enc command and flashed the BD-RE BU40N into 1.03 using this commandDrive InformationCode: Select all
Revision: 1.03
Can’t read UHD BLURAY..Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
DE_LG_BU40N_1.03_MK.bin
This firmware works for me & 4K/UHD discs.
Note that I flashed "DE_LG_BU40N_1.03_MK.bin" using the SDFtool.exe in a Windows 11 VM (see my previous reply).
MakeMKV disc info with a 4K/UHD disc, that is rippable:
[b]Disc Information[/b]
Label: SPIDER_MAN_ACROSS_SPIDER_VERSE
Timestamp: 2023-07-13 15:43:25
Protection: AACS2.0/C v77
Data capacity: 81.32 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Thanks,
Frank
It's the same firmware. He just used the one in the original MakeMKV firmware pack. Mine are named better for easier reading as it's much easier to read DE_LG_BU40N_1.03_MK than HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934nicholfd wrote: ↑Wed Jan 21, 2026 1:45 amI'm not sure where your firmware came from. This is the firmware I use, from the "All you need..." firmware download:B12ian wrote: ↑Tue Jan 20, 2026 5:52 pmHello
Revision: 1.03
MakeMKV disc info with a 4K/UHD disc, that is rippable:Ps. Be sure you've disconnected/power cycled the drive, after flashing.Code: Select all
[b]Disc Information[/b] Label: SPIDER_MAN_ACROSS_SPIDER_VERSE Timestamp: 2023-07-13 15:43:25 Protection: AACS2.0/C v77 Data capacity: 81.32 Gb Disc type: BD-ROM UHD Number of layers: 3 Bus encryption flags: 80
Thanks,
Frank
I tried Win11+SDFtool, same error-can’t decrypt a disc (WB). BU40N is from Germany, any difference with FW?MartyMcNuts wrote: ↑Wed Jan 21, 2026 2:25 amIt's the same firmware. He just used the one in the original MakeMKV firmware pack. Mine are named better for easier reading as it's much easier to read DE_LG_BU40N_1.03_MK than HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934nicholfd wrote: ↑Wed Jan 21, 2026 1:45 amI'm not sure where your firmware came from. This is the firmware I use, from the "All you need..." firmware download:B12ian wrote: ↑Tue Jan 20, 2026 5:52 pmHello
Revision: 1.03
Thanks,
Frank
I’ll try another disc tomorrow
dialogueravenous
Is the "Silverstone TS14 slimsata 9.5mm to USB-Marty" the same as this? Says SST-TS14, then in the product photos it says "TS14B":
https://www.amazon.com/Silver-Stone-Opt ... B019OBKWBW
I've never heard of country/source of the drive mattering for firmware.B12ian wrote: ↑Wed Jan 21, 2026 4:12 amI tried Win11+SDFtool, same error-can’t decrypt a disc (WB). BU40N is from Germany, any difference with FW?MartyMcNuts wrote: ↑Wed Jan 21, 2026 2:25 amIt's the same firmware. He just used the one in the original MakeMKV firmware pack. Mine are named better for easier reading as it's much easier to read DE_LG_BU40N_1.03_MK than HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934nicholfd wrote: ↑Wed Jan 21, 2026 1:45 am
Thanks,
Frank
What is the Mfg/model of the USB drive you purchased, as sold retail? What was on the box? Are you sure it was a BU40N drive internally?
Do you have 2 x USB or 1 x USB + 1 x power connections to the drive? 4K/UHD require more power than audio/DVD/Blu-Ray. Single USB ports/connections typically cannot supply enough power to a drive for 4K/UHD.
The Amazon link is an over-priced slim optical drive sized case for a SATA HD/SSD - look at the pictures from the 7th one on.dialogueravenous wrote: ↑Wed Jan 21, 2026 4:17 amIs the "Silverstone TS14 slimsata 9.5mm to USB-Marty" the same as this? Says SST-TS14, then in the product photos it says "TS14B":
It will not hold a slim-line optical drive.
That’s it-more power to it.nicholfd wrote: ↑Wed Jan 21, 2026 4:25 amI've never heard of country/source of the drive mattering for firmware.B12ian wrote: ↑Wed Jan 21, 2026 4:12 amI tried Win11+SDFtool, same error-can’t decrypt a disc (WB). BU40N is from Germany, any difference with FW?MartyMcNuts wrote: ↑Wed Jan 21, 2026 2:25 am
My friend has the 43888 and he said he could rip 4K with one usb cable.
I bought 43888, hoping it would Pioneer but I lost the lottery-BU40N.
Thanks for reminding me about the power supply.
I’ll try that tomorrow.
Thank you again
Yes, that is the same. It should include both the 9.5mm drive enclsoure and also a HDD rack to fit in a 9.5mm drive bay.dialogueravenous wrote: ↑Wed Jan 21, 2026 4:17 amIs the "Silverstone TS14 slimsata 9.5mm to USB-Marty" the same as this? Says SST-TS14, then in the product photos it says "TS14B":
Your issue is not firmware related (unless using Linux). You have flashed the drive and the info looks fine. What happens when you insert a UHD disc? If the disc does not even show in MakeMKV,B12ian wrote: ↑Wed Jan 21, 2026 5:00 amThat’s it-more power to it.nicholfd wrote: ↑Wed Jan 21, 2026 4:25 amI've never heard of country/source of the drive mattering for firmware.
Thank you again
1. Clean the disc.
2. Always insert the disc and let the OS initialise it first before you open up MakeMKV.
If you are using Linux, it is recommended to use firmware BU40N 1.00.
Also, it is best to use USB ports direct from the motherboard, USB-C if possible or use an AC self-powered USB hub of at least 24w. Do not use case ports for optical drives as they often have poor quality wiring and may not provide enough constant power.
Now, if you get an error or the disc won't decrypt, copy and paste the log window text.
