UHD Starship Troopers DUMP
brown1480
Post by brown1480 »
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167178240, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167245824, attempting to work around
Hash check failed for file 00336.m2ts at offset 167307264, file is corrupt.
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167350272, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167350272-167356416, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167356416, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167393280, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167626752, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167626752-167632896, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167632896, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167632896-167639040, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167639040, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167245824-167251968, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167270400, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167270400-167276544, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167276544-167288832, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167288832, attempting to work around
The source file '/BDMV/STREAM/00336.m2ts' is corrupt or invalid at offset 167344128, attempting to work around
Failed to save title 0 to file //jrbnas/plex/Movies/Starship Troopers_t00.mkv
Re: UHD Starship Troopers DUMP
Post by SamuriHL »
Clean the disc. I don't care if it "looks clean". Clean the disc.
