UHD capable drive - UK based
Re: UHD capable drive - UK based
Post by Billycar11 » Tue Jan 20, 2026 12:10 pm
Headbanger wrote: Tue Jan 20, 2026 11:48 am Thanks Coopervid.
What drive(s) are the 212T and 212V variants of? So confusing!
HB
212dbk ubk s12 whatever all the same
Post by Coopervid » Wed Jan 21, 2026 10:54 am
Coopervid wrote: Tue Jan 20, 2026 11:29 am
Headbanger wrote: Tue Jan 20, 2026 7:11 am I found this article on the Pioneer 12 series (although not all variants are listed). Looks like they all have an identical drive with differing externals but with different capabilities enabled. Makes sense because as long as they don’t have Pioneer’s latest firmwares installed, they can all be cross flashed.
https://www.cdrinfo.pl/artykuly/artykul ... 12English/
I ordered another pro version from Scan to keep as my last resort backup should both my current 2 fail. It again came with a Pionner 212T drive now flashed as the UHD variant.
HB
The 212BK and 212DBK have a plastic laser lens instead of a glass lens. Not important for reading UHDs when crossflashed but writing performance on 3 and 4 layer discs is worse according to asmcom who performed tests for comparison.
Thanks Coopervid.
HB
Like said the BK and DBK use a plastic laser lens. The Vinpower 212V has some reinforced gears compared to the others as the purpose is to duplicate discs on a large scale.
Headbanger
Post by Headbanger » Wed Jan 21, 2026 12:32 pm
Coopervid wrote: Wed Jan 21, 2026 10:54 am
Thanks Coopervid.
HB
Thanks so are the 212T and 212V variants of the BK/DBK and therefore also have the plastic lens or do these have a glass laser lens?
As you say won’t matter for reading discs but it may be a consideration for some who are also burning discs.
HB
Post by Coopervid » Wed Jan 21, 2026 12:37 pm
I haven't analyzed which drives show as 212T. Are the ASUS limited to burn 50GB discs like the 209DBK? That would be an indication.
Headbanger
Post by Headbanger » Wed Jan 21, 2026 12:56 pm
Coopervid wrote: Wed Jan 21, 2026 12:37 pm I haven't analyzed which drives show as 212T. Are the ASUS limited to burn 50GB discs like the 209DBK? That would be an indication.
Not sure tbh - specs don’t state max disc size.
Are you able to tell from the specs?:
https://www.asus.com/uk/motherboards-co ... /techspec/
Edit - actually they do state quadruple layer 128GB
Write Speed (max)
BD-R : 16X
BD-R(SL, M-DISC) : 4X
BD-R(DL) : 12X
BD-R(TL) : 8X
BD-R(QL) : 6X
BD-RE : 2X
DVD+R : 16X
DVD-R : 16X
DVD+R(SL, M-DISC) : 4X
DVD+RW : 8X
DVD-RW : 6X
DVD+R(DL) : 8X
DVD-R(DL) : 8X
DVD-RAM : 5X
CD-R : 40X
CD-RW : 24X
Whereas for the 212V it is limited to DL/50GB https://www.vinpowerdigital.com/product ... r-bdr-212v
So looking at the drive variant details on cdrinfo, it looks like the 212V is likely a variant of BDR-212DBK (plastic lens) and 212T is likely a variant of BDR-S12XLT (glass lens).
HB
Post by Coopervid » Wed Jan 21, 2026 2:42 pm
Headbanger wrote: Wed Jan 21, 2026 12:56 pm
Write Speed (max)
BD-R : 16X
BD-R(DL) : 12X
BD-R(TL) : 8X
BD-R(QL) : 6X
BD-RE : 2X
DVD+R : 16X
DVD-R : 16X
DVD+RW : 8X
DVD-RW : 6X
DVD+R(DL) : 8X
DVD-R(DL) : 8X
DVD-RAM : 5X
CD-R : 40X
CD-RW : 24X
HB
Don't bother and don't burn discs. Save the laser for reading as long as you can and store to HDD.
Vildar
Post by Vildar » Sun Jan 25, 2026 9:27 am
Just got this exact drive, from scan too.
It's identical to the op's.
Any chance I could possibly get some assistance aswell?
Post by Billycar11 » Sun Jan 25, 2026 9:35 am
Vildar wrote: Sun Jan 25, 2026 9:27 am Just got this exact drive, from scan too.
sure just email me your drive info section see below for email
Vildar
Post by Vildar » Sun Jan 25, 2026 10:07 am
I have emailed you
Post by Billycar11 » Sun Jan 25, 2026 12:04 pm
Vildar wrote: Sun Jan 25, 2026 10:07 am I have emailed you
sent you the flasher
Vildar
Post by Vildar » Sun Jan 25, 2026 12:29 pm
Just seen, thanks
Currently a little busy but once I'm back home I'll run it and let you know how it goes.
Vildar
Post by Vildar » Sun Jan 25, 2026 2:45 pm
All is good. I can now read UHD discs! Aswell as the newest Blu-ray I have from 2025. Time to backup!
SPoD-Man
Post by SPoD-Man » Sun Feb 08, 2026 5:50 pm
Hello
I too have the same ASUS external drive as Headbanger; could someone please advise how to update this drive to allow UHD access ready for future use.
The drive MakeMKV info is as follows:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: .....
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
Many thanks
Post by Billycar11 » Mon Feb 09, 2026 12:31 am
SPoD-Man wrote: Sun Feb 08, 2026 5:50 pm Hello
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Many thanks
Yes just email me that drive info section see below for email
SPoD-Man
Post by SPoD-Man » Mon Feb 09, 2026 3:21 pm
Hi Billycar,
Email sent as requested.
Many thanks
