Recommended Drives for (Blu-ray) Recovery
CartridgeUnit
#1 Post by CartridgeUnit » Tue Jan 20, 2026 4:05 am
I am working on trying to recover the video files from a few blu-ray discs for a friend using ddrescue. As MakeMKV fails to retrieve some video files. The thing is that these discs are of his wedding from over 10 years ago and the videography must have used some cheap blu-ray discs. As one appears to have delaminating issues and the other appears to have either a smaller delaminating issue or a slight crack/scratch (the latter disc might not be recoverable, but unsure). Are there any recommended blu-ray drives that could probably scan these better than my portable slim LG drive? I imagine I would be told that a Pioneer could do that job, but I unfortunately found out the hard way over the weekend that Pioneer is no more as of 2024/2025. So, is there a drive (or type of drive) on the market today that I could buy that would have better luck scanning these? Also, I do tend to rip (UHD) Blu-rays from time to time, so I would eventually use said drive for that after this project is done. I only have the one slim blu-ray drive rn anyway lol.
P.S. Also, anyone my friend knows who was given a copy of these wedding discs does not know where they are anymore. So, as far as I'm concerned, these are a one-of-a-kind so far.
Re: Recommended Drives for (Blu-ray) Recovery
#2 Post by dcoke22 » Tue Jan 20, 2026 4:23 am
If you're using ddrescue and there's a risk the disc might disintegrate in the drive, I wouldn't use a LibreDrive capable drive to do it. I wouldn't want the possibility of a million disc pieces floating around in my optical drive potentially damaging it.
Since the disc is a burned disc from a videographer, it probably doesn't have any encryption. I would guess any blu-ray capable drive could work.
Is the videographer still in business? Could your friend contact them and see if they still have a digital copy of their video?
CartridgeUnit
#3 Post by CartridgeUnit » Tue Jan 20, 2026 4:46 am
dcoke22 wrote: Tue Jan 20, 2026 4:23 am If you're using ddrescue and there's a risk the disc might disintegrate in the drive, I wouldn't use a LibreDrive capable drive to do it. I wouldn't want the possibility of a million disc pieces floating around in my optical drive potentially damaging it.
I'm not sure tbh. The one disc I'm giving more attention to has some slight delamination/bubbling. I have gotten some progress by rolling/pressing down with my fingers but it comes undone after a bit and then it struggles to read again (just seems like a blue vinyl-like material). Was wondering if maybe a different type of drive could read through the layer better/quicker.
kaysee
#4 Post by kaysee » Tue Jan 20, 2026 3:26 pm
Use multiple desktop drive models. I recommend starting with an ASUS or an LG with ASUS firmware. This disables the LG jamless playback feature which produces bad data in error regions. LG portable/laptop drives do not have ASUS firmware available, and I have my doubts about how Pioneer laptop drives handle errors, with a BDR-TD05 confirmed to have produced junk data with no error signals with a damaged DVD.
In ddrescue, do only the first phase (fast copying), passes 1 and 2 (forward and reverse) only using the first drive. This will rapidly copy the good parts of the disc, which is typically most of it. Then put the disc in the second drive and do the same, which will copy some of the blocks that were skipped due to errors or slowness in the first round. I set the minimum speed requirement fairly high, so moderately slow parts of the disc are skipped in this phase.
After that, gradually move to the next phases (scrape, trim, and retry), alternating between the drives. These will take longer and longer.
Along the way, it is good to back up your image and map files, since a user error or surprise behavior by a drive could contaminate your rescued data which took a long time to create.
CartridgeUnit
#5 Post by CartridgeUnit » Tue Jan 20, 2026 5:20 pm
Just for clarification, when you say to use a desktop drive, do you mean to use an internal drive? Or can it be an external drive that is just not a slim version? My PC does not have a spot for a 5.25in drive, unfortunately.
#6 Post by dcoke22 » Wed Jan 21, 2026 2:36 pm
CartridgeUnit wrote: Tue Jan 20, 2026 5:20 pm Just for clarification, when you say to use a desktop drive, do you mean to use an internal drive? Or can it be an external drive that is just not a slim version? My PC does not have a spot for a 5.25in drive, unfortunately.
Pretty sure kaysee means a 5.25in drive as opposed to a mobile/laptop drive. It doesn't matter if it is installed internally in your machine or in an external enclosure and connected via USB.
kaysee
#7 Post by kaysee » Wed Jan 21, 2026 5:24 pm
Pretty much. I am fairly confident that dkoke22 knows that these are all (whether portable or desktop) actually 5.25 inch drives, describing the diameter of the discs, not the thickness, height, volume, or mass of the drives.
I was recommending what I think of as "normal", full-sized drives, either installed internally in a non-laptop computer, or in a full-sized enclosure, or (what I do) just sitting on a desk with a SATA-USB adapter that has AC power.
CartridgeUnit
#8 Post by CartridgeUnit » Thu Jan 22, 2026 5:04 am
Sounds good. I'll give the good old college try and see if I get better results. Thank you!
CartridgeUnit
#9 Post by CartridgeUnit » Thu Feb 05, 2026 4:42 am
Okay, I bought a 5.25 internal Asus BW-16D1HT Blu-ray drive from Newegg a few weeks ago. Seems to be the only place that sells 5.25 internal Asus Drives nowadays. I also bought a Unitek Y-3324 USB to sata cable (as suggested in the Flashing Guide). However, when using DDrescue, it appears this drive gives up almost as soon as it is given pushback by a slight damage on the disc (from what I can tell). After it runs into a read it doesn't like, I get the following error message: "ddrescue: /dev/sr0: Fatal error reading the input file: Permission denied (errno=13)". This never happened with my slim drive. It usually would still try to crawl along. Using one disc with this drive, I got as far as 1.5% recovered before it gave me that message (I re-tried multiple times). The second disc, I got as far as 42.21%.
There are a few things that I noticed--along with a few questions--that could complicate things, but I'm not sure. (1) the drive appears to be older than presented. It looks like one of those drives described in this thread (viewtopic.php?f=19&t=40898&p=193858&hil ... HT#p193858) where they are re-cased and re-stickered in China to look somewhat newer. (2) Given this revelation, does this present an issue as to why DDrescue spits out this error, unlike my slim drive? Is the Unitek adapter related to any of these errors? (3) Also, the drive was definitely an Open-Box item, even though I'm pretty sure I ordered NEW. (4) Would an ASUS BW-16D1X-U be any better?
CartridgeUnit
#10 Post by CartridgeUnit » Thu Feb 12, 2026 4:16 am
Any ideas?
#11 Post by Coopervid » Thu Feb 12, 2026 12:17 pm
CartridgeUnit wrote: Thu Feb 12, 2026 4:16 am Any ideas?
Post your Makemkv info for that ASUS.
kaysee
#12 Post by kaysee » Fri Feb 13, 2026 12:31 pm
I have a Unitek adapter with AC power and it turns out to require a powered USB connection for the data transfer. In other words, connecting this to a hard drive or optical drive, the adapter needs to have its AC connection as well as the USB connector going to a powered port.
CartridgeUnit
#13 Post by CartridgeUnit » Sat Feb 14, 2026 2:05 am
Coopervid wrote: Thu Feb 12, 2026 12:17 pm
OS device name: I:
Manufacturer: Generic
Product: External
Revision: 3.11
Serial number: KLTP55G5647
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 77
CartridgeUnit
#14 Post by CartridgeUnit » Sat Feb 14, 2026 2:07 am
kaysee wrote: Fri Feb 13, 2026 12:31 pm I have a Unitek adapter with AC power and it turns out to require a powered USB connection for the data transfer. In other words, connecting this to a hard drive or optical drive, the adapter needs to have its AC connection as well as the USB connector going to a powered port.
I can transfer data. I also I ripped a DVD the other day with it just as an additional test. I have AC power and the USB connected.
#15 Post by Coopervid » Sat Feb 14, 2026 10:51 am
CartridgeUnit wrote: Sat Feb 14, 2026 2:05 am
OS device name: I:
Product: External
Revision: 3.11
This Unitek adapter seems to be an issue. It doesn't show all the drive's capabilities. DDRescue on an USB adapter isn't recommended anyway but if it's your only chance I recommend the BENFEI. Buy the one with power supply.
https://www.amazon.com/Benfei-Adapter-C ... r=8-4&th=1
