Blu ray rips stop early
I'm not sure where this should be poasted but I have been trying to rip region 2 TV series discs. MakeMKV rips them successfully up to one hour and 37 minutes. Are there settings that will get the rips to finish?
Re: Blu ray rips stop early
Can you copy and paste into a post on the forum the MakeMKV log of a failed rip?
I apologize in advance but I'm new to MakeMKV. Where do I find the failure log?
It is the output in the bottom section of the MakeMKV window. If you have debug logging turned on (on the General tab in MakeMKV's preferences) when you start MakeMKV it'll print out where the log file is located on your computer. The log starts fresh every time you start MakeMKV.
Thank you for the information and your patience! I will give this a try and post the log.
