and so many of them are fake the lg/asus and pioneers
many of the lgs are 2014 or older in new cases and they cant do UHD
the pioneers they are faking the higher end models by putting new front plates on
Integrate VLC with MakeMKV in prefrences so it can be used as the on-the-fly decrypter. Once integrated, just insert a disc, once the OS has initialised it, open up MakeMKV to enable libredrive then open up VLC.mikejsc wrote: ↑Sat Jan 17, 2026 2:08 amThis evening I flashed my LG BP50NB40 NB50 to BU40N 1.0 per the advice here. MakeMKV now will rip my 4K UHDs along with my BD and DVD, but VLC Media player will no longer play BD as well as and UHD discs. MakeMKV shows my drive info as:
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 61
Firmware version: 1.00
VLC Media Player error log has the following for any/all BD and UHD discs I've tried:
-- logger module started --
main: one instance mode ENABLED
main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
dvdnav error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
dvdnav warning: Can't open file VIDEO_TS.IFO.
dvdnav error: vm: vm: failed to read VIDEO_TS.IFO
dvdnav warning: cannot open DVD (F:)
dvdread error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
dvdread error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
dvdread warning: cannot open VMG info
-- logger module stopped --
Have I done something wrong? Is there a way to make VLC media player work? I also have cyberlink powerDVD 14 installed. It seems to work though it complains response may be slow and suggests I should check my drive's manufacturer site for the latest firmware update.
If I want to revert my drive back to it's original firmware, do I do that with the files in the firmware dump .tar file SDFtool Flasher created? If so, do I do each .bin file in sequence? Is there a proscribed order? Or do I just download the latest firmware file from LG and use that?
TIA for any help anyone can provide.
You need pretty decent hardware and the right codecs to play UHD discs as they use HEVC/h265 and HD audio.
Hello, can you help me? Do you have firmware for this drive please?T0mVerse wrote: ↑Mon Jan 12, 2026 10:13 amHello, I am new on here. I have a drive that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
I also want it.T0mVerse wrote: ↑Sun Jan 18, 2026 8:06 amHello, can you help me? Do you have firmware for this drive please?T0mVerse wrote: ↑Mon Jan 12, 2026 10:13 amHello, I am new on here. I have a drive that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Providing your drive information, like what you quoted but for YOUR drive, would be helpful. Different drives need different updates.I also want it.
sure just both of you email me your makemkv drive info sections see below for emailMorlenColdcrest wrote: ↑Mon Jan 19, 2026 2:44 pmI also want it.T0mVerse wrote: ↑Sun Jan 18, 2026 8:06 amHello, can you help me? Do you have firmware for this drive please?T0mVerse wrote: ↑Mon Jan 12, 2026 10:13 amHello, I am new on here. I have a drive that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Did you have a disc in the drive? The message was probably related to the disc, and a "bad" error message.B12ian wrote: ↑Mon Jan 19, 2026 11:05 pmmakemkv asked me to email them a tgz file for a BU40N
OS device name: /dev/rdisk6
Revision: 1.05
Serial number:
Highest AACS version: 82
