ASUS-SBW-06D2X-U
CarstenCarsten
ASUS-SBW-06D2X-U
Post by CarstenCarsten » Mon Jan 19, 2026 8:07 pm
Hej..
Er der en opdatering til denne.
Drevinformation
OS drevnavn: D:
Producent: ASUS
Produkt: SBW-06D2X-U
Revision: A102
Serienummer:
Firmwaredato: 2121-06-28 13:41
Krypteringsflag for databus: 1F
LibreDrive-information
Status: Muligt, men endnu ikke aktiveret
Drev-platform: MT1959
Mange tak på forhånd!
Re: ASUS-SBW-06D2X-U
Post by dcoke22 » Wed Jan 21, 2026 6:17 pm
Google Translate wrote: Hi..
Is there an update for this.
OS Drive Name: D:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial Number:
Firmware Date: 2121-06-28 13:41
Data Bus Encryption Flag: 1F
Status: Possible, but not yet enabled
Drive Platform: MT1959
Thank you very much in advance!
Since the drive platform is MT1959, you can flash it with the tools listed in the Ultimate UHD Drives Flashing Guide.
See the set of posts starting here: https://forum.makemkv.com/forum/viewtopic.php?p=191256#p191256
Google Translate wrote:Da drevplatformen er MT1959, kan du flashe den med de værktøjer, der er anført i den Ultimate UHD Drives Flashing Guide.
Se sættet af indlæg, der starter her: https://forum.makemkv.com/forum/viewtopic.php?p=191256#p191256
