Just received the Verbatim drive from Office Depot. Is someone able to assist with getting it flashed? Much appreciated.
OS device name: L:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 76
Drive platform: RS8511
Firmware version: 1.14
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.Orientalmushroom wrote: Sat Jan 17, 2026 11:40 pmHi Coopervid, I just picked one up and would like to know how to flash it as well. Will wait for your PM!
OS device name: F:
Revision: 1.14
Highest AACS version: 82
PM sent.curtis07 wrote: Sat Jan 17, 2026 11:37 pm Good afternoon! I found a Pioneer version of the Verbatim 43890 at Staples today (unbelievably lucky, and unfortunately the only drive there) and would like to flash it for UHD.Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Real_Derek
Hi Coopervid!
I have Pioneer BDR-UD03 drive and would like to get your instructions on how to make this drive read UHD discs
My makemkv drive info:
Revision: 1.05
Serial number:
Firmware date: 2015-11-24
Drive platform: RS8510
Firmware version: 1.05
Revision: 1.05
Serial number:
zaqqaz6917
Also offering a 25% sign up code.
blind-s33r
They were, I managed to grab a few but now their website says out of stock and everywhere around I check for pickup is also oos... but It was a nice last ditch find for some pioneers.zaqqaz6917 wrote: Sun Jan 18, 2026 10:44 pmIt seems currently Office depot usa is a good source for pioneer/verbatim ud-03 with pre 2023 terror firmware
Orientalmushroom
Couldn't send you a PM for some reason but thank you for the help. Worked perfectly and I'm up and running. I sent you a thank you!!!Coopervid wrote: Sun Jan 18, 2026 1:42 pmPM sent.Orientalmushroom wrote: Sat Jan 17, 2026 11:40 pmHi Coopervid, I just picked one up and would like to know how to flash it as well. Will wait for your PM!
OS device name: F:
Revision: 1.14
PM sent.HarmonKillerbrew wrote: Sun Jan 18, 2026 4:17 am Just received the Verbatim drive from Office Depot. Is someone able to assist with getting it flashed? Much appreciated.
OS device name: L:
Revision: 1.14
Serial number:
Real_Derek
Me too please. My message with the drive info is above.
sure just email me your drive info section see below
PM sent.Real_Derek wrote: Sun Jan 18, 2026 4:57 pm Hi Coopervid!
I have Pioneer BDR-UD03 drive and would like to get your instructions on how to make this drive read UHD discs![]()
Revision: 1.05
Serial number:
Real_Derek
Thank you so much! For some reason PMs aren't sending. So I'm thanking you here. Best wishes!
darknight
OS device name: E:
Revision: 1.11
Serial number:
Firmware date: 2018-11-28
Firmware version: 1.11
OS device name: E:
Revision: 1.11
Serial number:
Sure just email me that drive info see below for emaildarknight wrote: Tue Jan 20, 2026 8:33 pm Drive Information
OS device name: E:
Revision: 1.11
Serial number:
DC-2187
I also got one from there on friday. I wanted to buy more but decided to just get one at first and then saturday morning. they were all sold out. someone mentioned staples stores being a place to look. I have gone to 3 local stores and have scored 3 Verbatim 43890 drives. all with pioneer drives. if possible i recommend going into the stores to check. Online will only say to go to the store and check.blind-s33r wrote: Mon Jan 19, 2026 12:11 amThey were, I managed to grab a few but now their website says out of stock and everywhere around I check for pickup is also oos... but It was a nice last ditch find for some pioneers.zaqqaz6917 wrote: Sun Jan 18, 2026 10:44 pmIt seems currently Office depot usa is a good source for pioneer/verbatim ud-03 with pre 2023 terror firmware
