The Descendants
drunkwithpower
The Descendants
Post by drunkwithpower »
Getting the following error using two separate bluray players. I would normally say the media is corrupt but I just purchased this brand new from Wally World. I also ran a backup and it was successful which I thought was a good indication the media was good. Any thoughts?
AV synchronization issues were found in file 'J:/BluRayMoviesLacie/t05_The_Descendants.mkv' (title #6)
AV sync issue in stream 1 at 0:00:00.003 with duration of 10.666ms : 1 early frame(s) dropped at start
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 59811840, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 64112640, attempting to work around
Failed to save title 5 to file J:/BluRayMoviesLacie/t05_The_Descendants.mkv
0 titles saved, 1 failed
Darby67
Re: The Descendants
Post by Darby67 »
Just received my copy from Amazon.
Receiving the same error as "drunkwithpower", in addition the following:
MakeMKV v1.7.2, Mac 10.7.2
At disk load:
Loaded 38 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
DEBUG: Code 0 at 'A~T|cGbly_$`e>*:29400531
DEBUG: Code 0 at 'A~T|cGbly_$`e>*:29398254
DEBUG: Code 0 at 'A~T|cGbly_$`e>*:213139690
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed but no FUTs were obtained, errors may follow
When attempting to backup disk (main feature only):
DEBUG: Code 0 at ~(5g&`<]' zAM0tX!w"&:213133158
DEBUG: Code 2 at D>3rt?E{%9>iAT>>6dy:29398622
DEBUG: Code 149 at D>3rt?E{%9>iAT>>6dy:213135067
DEBUG: Code 438 at D>3rt?E{%9>iAT>>6dy:213135090
DEBUG: Code 0 at ZJ&V4Wr`DCv3JkHS#7(ls:29397955
Failed to save title 0 to file /Volumes/iTunesMedia/Movies A - R/The Descendants (2011)/t00_The_Descendants.mkv
Not sure if any other files would be of use, please advise.
MakeMKV_log.txt
(1.29 KiB) Downloaded 868 times
BlackDragon24
Re: The Descendants
Post by BlackDragon24 »
Same problem here. Mike, I submitted a BD+ dump file to svq@makemkv.com. Let us know if you need anything else.
sycro
Re: The Descendants
Post by sycro »
Same issue here at same spots. Guessing there's no need to add another dump, but let me know if you do need one.
crowfax
Re: The Descendants
Post by crowfax »
You should always send in your dumps. Better too much information than too little.
setarip_old
Re: The Descendants
Post by setarip_old »
@drunkwith power
Hi!
I also ran a backup
Have you tried creating an .MKV using the backup full disc copy as your source?
BlackDragon24
Re: The Descendants
setarip_old wrote:@drunkwith power
Hi!
I also ran a backup
I have, and no dice.
drunkwithpower
Re: The Descendants
The full backup was successful.
BlackDragon24
Re: The Descendants
drunkwithpower wrote:The full backup was successful.
He's asking if you tried to make the mkv file from the backed up copy.
I tried it myself and had no luck....failed in the exact same spot as when I tried to make the mkv file directly from disc.
drunkwithpower
Re: The Descendants
I had the same result with the backup copy - no joy. Same error.
setarip_old
Re: The Descendants
Seems very likely that a NEW BD+ SVQ is required...
BlackDragon24
Re: The Descendants
Mike has updated the BD+ SVQ.
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612
Currently making mkv from backed up, undecrypted copy of "The Descendants"
Thanks Mike!
drunkwithpower
Re: The Descendants
Thanks Mike!!!!
sycro
Re: The Descendants
Post by sycro »
Thanks! It appears to be working thus far!
Darby67
Re: The Descendants
Post by Darby67 »
Success, thank you!
