BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Hi Coopervid!
I'm interested in the firmware to enable UHD support on my drive.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL034841WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 31
Drive platform: RS8F00
Firmware version: 1.00/ID61
Thank you!
Revision: 1.00
Thank you!
PM sent.Edkun wrote: Wed Jan 14, 2026 12:04 am Hi Coopervid!
Revision: 1.00
Thank you!
Unkindpuddle
Good evening Coopervid.
I am looking to flash my BDR-212V for UHD. Thanks!
OS device name: G:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Highest AACS version: 82
Firmware version: ID06
OS device name: G:
Revision: 1.02
Serial number:
Thank you very much!
I'll flash the drive today, as I need to install Windows on a spare PC, and will report back here as I can't reply to PMs yet.
Sorry for the late reply.
PM sent.Unkindpuddle wrote: Thu Jan 15, 2026 1:04 am Good evening Coopervid.
OS device name: G:
Revision: 1.02
Serial number:
random_potato
Hello Coopervid! I'm also looking to flash my drive.
OS device name: /dev/sr0 (can use Windows to flash if needed)
Revision: 1.02
Serial number:
Edit: It worked! Thank you!
Revision: 1.02
Serial number:
Hi Coopervid!
I'm looking to flash my drive as well.
Revision: 1.02
Serial number:
Revision: 1.02
Serial number:
PM sent.random_potato wrote: Fri Jan 16, 2026 10:39 pm Hello Coopervid! I'm also looking to flash my drive.
Revision: 1.02
Serial number:
Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Does this drive look like it was flashed already? Is this something you can't tell from looking at the data. I know it just spins up then stops and ejects. Also @billycar11 sent me the auto flasher but I can't get past the part where it says configuration files missing. I suspect that isn't part of what Billy sent me as they must be available here in the database of flash tools and I'm supposed to pull the 3.10 file from there drag and drop??? I don't get it. Please go easy on me I'm not that savvy when it comes to this particular task.
Hi Coopervid!
Following the instructions provided by you, the crossflashing went out flawlessly, and my drive can now read UHD discs.
Once again, thank you very much!
Oh, I've sent you an e-mail.
PM sent.MusicMan wrote: Sat Jan 17, 2026 3:52 am Hi Coopervid!
I'm looking to flash my drive as well.![]()
Revision: 1.02
Serial number:
Post your Makemkv info.Rays1 wrote: Sat Jan 17, 2026 10:32 pm Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Pretty sure I helped you out in the email already correct?Rays1 wrote: Sat Jan 17, 2026 10:32 pm Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
And your all flashed now
Thank you!!! It's working now.
Hi Billycar11
I'm interested in the firmware to enable UHD support on my drive. I would appreciate the help. Thank you.
Revision: 1.01
Serial number: (Redacted)
Firmware date: 2021-07-20
Highest AACS version: 50
Firmware version: 1.01/ID06
Revision: 1.01
