Mr_Orange
Post by Mr_Orange » Fri Jan 16, 2026 3:58 am
jj2d2 wrote: Thu Jan 15, 2026 3:27 pm
Woodstock wrote: Sun Jan 04, 2026 12:14 am Pioneers depend on the firmware currently installed... What's your drive information?
I got ya, I just saw one on eBay was going to buy, but didn't want to jump until I knew. I did pass on it because its location was China, and I don't know what Tarrifs etc would look like LOL!!
Nevermind the tariffs, ever since the drive shortage started a huge number of Chinese sellers have suddenly listed supposed 4K UHD drives on eBay and Ali Express.
Caveat emptor!
Post by Billycar11 » Fri Jan 16, 2026 4:40 am
Mr_Orange wrote: Fri Jan 16, 2026 3:58 am
Caveat emptor!
and so many of them are fake the lg/asus and pioneers
many of the lgs are 2014 or older in new cases and they cant do UHD
the pioneers they are faking the higher end models by putting new front plates on
alec_llama
Post by alec_llama » Fri Jan 16, 2026 5:49 pm
I have a question on an LG drive I just got recently. It is an LG WH16N60 drive that is on firmware 1.03. I have succesfully ripped about 7 4K UHD discs areadly. I see the guide states to flash the firmware to 1.02. If there anything I will be missing by not flashing to 1.02?
shamgar_bn
Post by shamgar_bn » Fri Jan 16, 2026 6:49 pm
Hi all! I'm not new to MakeMKV, but I am new here to the forums :D
I'm running a MacBook Pro (M4 chip) and just purchased a new Verbatim 43888 (guts are BD-RE BU40N). I'm trying to take my firmware from 1.05 to 1.03 as the instructions advise, but I'm running into the issue where MakeMKV 1.17.7 fails to open on my computer. I have already tried a solution of using the beta key (as advised elsewhere in the forums) as well as using my original purchased key, neither of which have solved my issue.
I would've looked through the entire thread of replies, but there are over 230 pages of responses, so I was hoping someone might have answered this already and could just put me on the right track? I would be so grateful for some help here :D
Post by Woodstock » Fri Jan 16, 2026 11:26 pm
Important stuff is in the first couple of messages, which are edited if things change.
mikejsc
Post by mikejsc » Sat Jan 17, 2026 2:08 am
This evening I flashed my LG BP50NB40 NB50 to BU40N 1.0 per the advice here. MakeMKV now will rip my 4K UHDs along with my BD and DVD, but VLC Media player will no longer play BD as well as and UHD discs. MakeMKV shows my drive info as:
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.00
Serial number:
Firmware date: 2116-12-20 15:28
Highest AACS version: 61
Firmware version: 1.00
VLC Media Player error log has the following for any/all BD and UHD discs I've tried:
-- logger module started --
main: one instance mode ENABLED
main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
dvdnav error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
dvdnav warning: Can't open file VIDEO_TS.IFO.
dvdnav error: vm: vm: failed to read VIDEO_TS.IFO
dvdnav warning: cannot open DVD (F:)
dvdread error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
dvdread error: DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
dvdread warning: cannot open VMG info
-- logger module stopped --
Have I done something wrong? Is there a way to make VLC media player work? I also have cyberlink powerDVD 14 installed. It seems to work though it complains response may be slow and suggests I should check my drive's manufacturer site for the latest firmware update.
If I want to revert my drive back to it's original firmware, do I do that with the files in the firmware dump .tar file SDFtool Flasher created? If so, do I do each .bin file in sequence? Is there a proscribed order? Or do I just download the latest firmware file from LG and use that?
TIA for any help anyone can provide.
Post by MartyMcNuts » Sat Jan 17, 2026 2:54 am
mikejsc wrote: Sat Jan 17, 2026 2:08 am This evening I flashed my LG BP50NB40 NB50 to BU40N 1.0 per the advice here. MakeMKV now will rip my 4K UHDs along with my BD and DVD, but VLC Media player will no longer play BD as well as and UHD discs. MakeMKV shows my drive info as:
Revision: 1.00
Serial number:
Integrate VLC with MakeMKV in prefrences so it can be used as the on-the-fly decrypter. Once integrated, just insert a disc, once the OS has initialised it, open up MakeMKV to enable libredrive then open up VLC.
mikejsc
Post by mikejsc » Sat Jan 17, 2026 1:54 pm
Worked for BD, though VLC complained about not having Java for menus. Couldn't get UHD to open. Thanks for the response and tip. :)
Post by MartyMcNuts » Sun Jan 18, 2026 1:33 am
mikejsc wrote: Sat Jan 17, 2026 1:54 pm Worked for BD, though VLC complained about not having Java for menus. Couldn't get UHD to open. Thanks for the response and tip. :)
You need pretty decent hardware and the right codecs to play UHD discs as they use HEVC/h265 and HD audio.
T0mVerse
Post by T0mVerse » Sun Jan 18, 2026 8:06 am
T0mVerse wrote: Mon Jan 12, 2026 10:13 am Hello, I am new on here. I have a drive that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
Hello, can you help me? Do you have firmware for this drive please?
Post by Woodstock » Mon Jan 19, 2026 2:46 pm
I also want it.
Providing your drive information, like what you quoted but for YOUR drive, would be helpful. Different drives need different updates.
Post by Billycar11 » Mon Jan 19, 2026 3:33 pm
MorlenColdcrest wrote: Mon Jan 19, 2026 2:44 pm
T0mVerse wrote: Sun Jan 18, 2026 8:06 am
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
I also want it.
sure just both of you email me your makemkv drive info sections see below for email
B12ian
Post by B12ian » Mon Jan 19, 2026 11:05 pm
makemkv asked me to email them a tgz file for a BU40N
OS device name: /dev/rdisk6
Revision: 1.05
Serial number:
Highest AACS version: 82
nicholfd
Post by nicholfd » Tue Jan 20, 2026 1:09 am
B12ian wrote: Mon Jan 19, 2026 11:05 pm makemkv asked me to email them a tgz file for a BU40N
Revision: 1.05
Serial number:
Did you have a disc in the drive? The message was probably related to the disc, and a "bad" error message.
The drive needs to be flashed with the SDFtool.exe & the firmware "DE_LG_BU40N_1.03_MK.bin" from the "All the firmware..." download on the same page.
Thanks,
Frank
B12ian
Post by B12ian » Tue Jan 20, 2026 4:33 am
Yeah you’re right.
I flashed the driver with Terminal (macOS) successfully but the firmware didn’t update. Doh, I have a newer version (1.18.2) makeMKV.
Any idea when I can flash it? No rush.
Have a good day
