Switchblade Romance / High Tension (2003) Dump submitted
javicozarcastillo
Post by javicozarcastillo » Mon Jan 12, 2026 11:02 pm
I submitted via e-mail the dump file for Switchblade Romance / High Tension. It's the spanish edition called "Alta tensión".
This is the link to the file, if anybody can help me with this: https://drive.google.com/file/d/1hzVUPw ... sp=sharing
The message I receive from MakeMKV is that the AACS is too new and then fails to decrypt.
Javi
EdibleFungi
Re: Switchblade Romance / High Tension (2003) Dump submitted
Post by EdibleFungi » Tue Jan 13, 2026 10:36 pm
I tried to decrypt the same disk, and the same error happens.
So far this has been the first time a disk I bough failed to decrypt.
EdibleFungi
Post by EdibleFungi » Thu Jan 15, 2026 4:38 pm
I used aacs_info (from libaacs utils) alongside the latest device keys to get the disk VUK, added it to the KEYDB.cfg, and then MakeMKV had no trouble decrypting the BD.
tommik128
Post by tommik128 » Fri Jan 16, 2026 11:30 am
In Windows you can use the KeyDB Helper (Windows Only) program that will unlock standard blu-ray discs even on Pioneer drives and even offline. And it is very user friendly, just click the buttons, no messing around...
