Buffalo BRXL-PT6U2VB BN 14 Firmware Help
BubbleStar
#1 Post by BubbleStar » Fri Jan 16, 2026 12:34 am
I got this here drive and i want to make it read UHD discs. What firmware should i flash it to?
OS device name: J:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number: MODM59H0850
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 82
Re: Buffalo BRXL-PT6U2VB BN 14 Firmware Help
#2 Post by Billycar11 » Fri Jan 16, 2026 12:49 am
see guide below or email me or marty for an auto flasher
its a bu40n with encrypted fw if your using the guide
BubbleStar
#3 Post by BubbleStar » Fri Jan 16, 2026 1:17 am
Billycar11 wrote: Fri Jan 16, 2026 12:49 am see guide below or email me or marty for an auto flasher
do i have to decrypt the firmware first or can i install the bu40n firmware directly?
#4 Post by MartyMcNuts » Fri Jan 16, 2026 1:36 am
BubbleStar wrote: Fri Jan 16, 2026 1:17 am do i have to decrypt the firmware first or can i install the bu40n firmware directly?
No, BU40N 1.03-MK replaces the encrypted firmware.
BubbleStar
#5 Post by BubbleStar » Fri Jan 16, 2026 1:52 am
MartyMcNuts wrote: Fri Jan 16, 2026 1:36 am
Worked like a charm. Thanks :D
(tho i have to plug in both usbs for it to read uhd disc lol)
#6 Post by MartyMcNuts » Fri Jan 16, 2026 2:43 am
BubbleStar wrote: Fri Jan 16, 2026 1:52 am
Yes, you should always plug in both USB plugs as one generally provides the additional power that the drive needs.
Selex
#7 Post by Selex » Sat Feb 07, 2026 3:22 pm
Thanks this helped. It was driving me nuts the last few days on Ubuntu. It would read on Windows but not Ubuntu. I flashed the firmware and it worked. The LG drive was working but I flashed that a while ago.
