LibreDrive for Pioneer drives
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer: CCDL089824WL
Firmware-Datum: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
OS-Gerätename: E:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
PM sent.IngoK wrote: Thu Jan 08, 2026 7:55 pm Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Just got a verbatim slim drive that is a pioneer drive inside. Do I still need a special pioneer flasher to update this?
I was looking at the flasher guide, but doesn't seem to cover these drives. Maybe I'm missing something.
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8511
Firmware version: 1.14
Yes it can do UHD just email me your makemkv drive info section see below for emailnatfu40 wrote: Thu Jan 15, 2026 3:46 pm Just got a verbatim slim drive that is a pioneer drive inside. Do I still need a special pioneer flasher to update this?
Drive Information OS device name: J: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
I'm not sure if my BDR-XD07S drive is supported yet, but here is the info:
OS device name: /dev/sr0
Product: BD-RW BDR-XD07
Revision: 1.05
Serial number: BFDL012725UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: Pioneer RS8D30
Firmware version: GENE
If you download the latest SDF.bin, then you should be able to enable LibreDrive however, it still cannot read UHD discs or be cross-flashed at this point in time.thathuman wrote: Fri Jan 16, 2026 10:43 pm I'm not sure if my BDR-XD07S drive is supported yet, but here is the info:Code: Select all
Drive Information OS device name: /dev/sr0 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.05 Serial number: BFDL012725UC Firmware date: 2023-01-06 Bus encryption flags: 13 Highest AACS version: 76 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8D30 Firmware version: GENE
JohnRunge316
Hi everyone,
I'm trying to flash my Pioneer BD-RW BDR-S09 drive (firmware 1.34) to enable LibreDrive.
Here's my drive info:
MSG:1005,0,1,"MakeMKV v1.18.2 win(x64-release) started","%1 started","MakeMKV v1.18.2 win(x64-release)"
DRV:0,2,999,28,"BD-RE PIONEER BD-RW BDR-S09 1.34 QGDL018648CN","INDEPENDENCE_DAY_RESURGENCE","D:"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
Can someone please PM me the SDFTool flasher and the firmware files for this drive (e.g., 1.03-MK.bin and a downgrade like GENE.bin for the RS8600 platform)? I've read the Ultimate UHD Drives Flashing Guide and appreciate any help!
Thanks,
John
Thanks,
John
Sure just email me your makemkv drive info section in plain text see below for emailJohnRunge316 wrote: Sat Jan 17, 2026 2:39 pm Hi everyone,
Thanks,
John
Stella1020
Hi, I flashed my original Pioneer BDR-212V from firmware v1.00 to v1.02, as I serached the web it says this version should support Liberdrive...However when I done the flashing the Liberdrive status changes to "Possible,not yet enabled", what can I do? Heres the output from makemkv:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: ACDL006136WL
Firmware date: 2022-05-31
Firmware version: ID06
Revision: 1.02
Don't ever update your drive from the manufacturer flashers they will only hurt you.Stella1020 wrote: Sat Jan 24, 2026 3:19 pm Hi, I flashed my original Pioneer BDR-212V from firmware v1.00 to v1.02, as I serached the web it says this version should support Liberdrive...However when I done the flashing the Liberdrive status changes to "Possible,not yet enabled", what can I do? Heres the output from makemkv:
Revision: 1.02
Luckily your drive can still be flashed to do UHD see below for email to send the makmkv drive info section to
Hello, I just started looking into NAS storage units since I just got out of college and don't really have the money to spend on subscriptions. I want to have my own media collection to where I can have my DVDs, blu-ray, and 4K UHD movies digitally copied. I am new and not really understanding all of this, and don't really have $200-300 to drop on a Pioneer/LG/Asus driver that comes with UHD capability. I came upon this forum and was curious about how to tell what the drive platform is of a optical driver is before buying? I was thinking about going with Pioneer either BDR-212DBK or BDR-209MBK. Do you think either one of these will need to be flashed or anything in order to work with makeMKV?mike admin wrote: Fri Feb 11, 2022 3:02 pm The main work to support Pioneer drives is done. MakeMKV should work with most Pioneer drives in LibreDrive mode. All drives starting from BDR-208 should be (eventually) supported, including rebranded ASUS/Optiarc/Verbatim clones.
This can be checked by drive platform:
RS1xxx - old firmware, could be technically supported, but too much hassle to make it happen. Likely would stay unsupported.
RS8000 - transitional firmware, mostly BDR-207 drives. Likely would stay unsupported.
RS8xxx and later, including RS9xxx RSAxxx and so on. Should be supported.
At the time of this writing none of the Pioneer drives require firmware update - they should just work.
If youre drive is listed above but is not supported, it means that it is not yet added to SDF.bin . Please post the drive model here.
Please do post any Pioneer specific issues in this topic.
both of those can do UHD after being flashed but they need fw before 12/22 or they cant be cross flashedlitlucky wrote: Sun Jan 25, 2026 4:05 am
Ahh it seems that those are listed as $75 and $80 on Pioneer website but are not longer made, would you recommend any others that would be less than $100 that would just need to be flashed?Billycar11 wrote: Sun Jan 25, 2026 4:47 amboth of those can do UHD after being flashed but they need fw before 12/22 or they cant be cross flashedlitlucky wrote: Sun Jan 25, 2026 4:05 am
a drive below $100 is almost impossible to find now as they have been ut of production for over a year all the pioneers and lg stopped a few months ago toolitlucky wrote: Sun Jan 25, 2026 5:05 am
i still have some xd08 if you want one but over $100 but still half the price of the ebay ones
Just a little out of my price range. I guess I'll have to just invest after a few months into my full-time job to get that much money. I'm assuming the LG GH24NSC0B isn't a good one either?Billycar11 wrote: Sun Jan 25, 2026 5:19 ama drive below $100 is almost impossible to find now as they have been ut of production for over a year all the pioneers and lg stopped a few months ago toolitlucky wrote: Sun Jan 25, 2026 5:05 am
