Post by RESET_9999 » Thu Jan 15, 2026 11:19 am
deadchip12
Post by deadchip12 » Thu Jan 15, 2026 11:01 pm
I just found out the ugoos am6b+ is no longer sold anywhere in my country. Now I dread the day mine dies.
Still no other devices that are capable of the same things as this box?
TickTock
Post by TickTock » Fri Jan 16, 2026 11:16 am
I have been using my Sony X700 to play DV content. Annoyingly my TV (Panasonic GZ950) doesn't support TV led DV, as I was led to believe when I made the purchase.
@RESET_9999 or anyone else knowledgable, are there any viewing benefits to replacing my X700 with a Ugoos AMB6+ when my TV only supports player led DV from external sources?
Post by RESET_9999 » Fri Jan 16, 2026 11:38 am
yes the ugoos with avdvplus CE improves lldv a lot
safariff
Post by safariff » Fri Jan 16, 2026 2:38 pm
Video
Duration                                 : 1 h 56 min
Bit rate                                 : 76.3 Mb/s
Bits/(Pixel*Frame)                       : 0.384
Stream size                              : 62.1 GiB (95%)
Writing library                          : ATEME Titan File 3.9.12 (4.9.12.4)
Maximum Content Light Level              : 3991 cd/m2
Maximum Frame-Average Light Level        : 257 cd/m2
Anyone know why the DV profile I typically see is not shown in the "HDR format" line? (framestor remux)
TickTock
Post by TickTock » Fri Jan 16, 2026 7:33 pm
RESET_9999 wrote: Fri Jan 16, 2026 11:38 am yes the ugoos with avdvplus CE improves lldv a lot
Thanks, I'm going to place an order for the AMB6+.
Trees
Post by Trees » Fri Jan 16, 2026 11:03 pm
safariff wrote: Fri Jan 16, 2026 2:38 pm
Video
When is the encoding date? I believe Framestor used an older version of MakeMKV and/or MediaInfo for a while, which didn't inclue the DV flag, or something along those lines. What does a modern version of MediaInfo say?
Epedemic
Post by Epedemic » Fri Jan 16, 2026 11:42 pm
So us AM6b+ owners are now in a situation where we are blessed with 3 different current builds/paths:
"OG" cpm on A15-HEVC, seemingly focusing on only full bitrate remux/lossless audio. https://github.com/cpm-code/xbmc/releases
avdvplus, currently on release 5 (which is what I am running right now), focusing on everything within reason and DV improvements in general. https://github.com/avdvplus/Builds/releases
U3k on B11, similar to avdvplus, but also backporting stuff from Kodi 22 (mostly GUI rendering stuff if i read it correctly?), maybe halted/discontinued as the repo is archived. https://github.com/CE-Repo/xbmc/releases/tag/B11
My only issues, which persist across all 3 versions are random crashes, completely taking down the AM6b+ , and some DV content completely blanking the screen (on a scene by scene basis) on my LG E6. (Latest content is Slow Horses S05 and Fallout S02 P5 versions, in which every episode has issues sooner or later), which can be fixed by removing CM4.0 using dovi_scripts, which are fine, but not super nice, as this can happen at any point in a movie/show, such as 30 minutes into a movie, which is not really when one would want to start running scripts on a file.
Just wondering if there is a preference / comparison, as i have lost the thread by now :P
Post by RESET_9999 » Sat Jan 17, 2026 12:02 am
Epedemic wrote: Fri Jan 16, 2026 11:42 pm So us AM6b+ owners are now in a situation where we are blessed with 3 different current builds/paths:
CPM and Jamal (u3k) have both retired and are no longer working on this project. At this point, avdvplus is the only build that should be used.
If you haven't already, you should open a ticket regarding these crashes. The issue is likely easy to fix, it's probably related to the fact that you have a first gen oled tv.
safariff
Post by safariff » Sat Jan 17, 2026 11:02 pm
Trees wrote: Fri Jan 16, 2026 11:03 pm
Video
Movie name                               : Ocean's Eleven (2001)
Encoded date                             : UTC 2024-04-25 14:25:22
Writing application                      : mkvmerge v83.0 ('Circle Of Friends') 64-bit
Writing library                          : libebml v1.4.5 + libmatroska v1.7.1
IMDB                                     : tt0240772
TMDB                                     : movie/161
Trees
Post by Trees » Thu Jan 22, 2026 12:33 am
safariff wrote: Sat Jan 17, 2026 11:02 pm
Video
IMDB                                     : tt0240772
TMDB                                     : movie/161
But it does show DV in the HDR format line, right?
Regardless, the P5 versions are always better than the P8 versions, HDR-wise.
At least according to this.
safariff
Post by safariff » Sat Jan 24, 2026 7:23 am
Trees wrote: Thu Jan 22, 2026 12:33 am
Trees wrote: Fri Jan 16, 2026 11:03 pm When is the encoding date? I believe Framestor used an older version of MakeMKV and/or MediaInfo for a while, which didn't inclue the DV flag, or something along those lines. What does a modern version of MediaInfo say?
IMDB                                     : tt0240772
TMDB                                     : movie/161
Yes still in the format line besides that little bit missing
Looking at that link, I feel like a P8 UHD Remux would still be slightly better than a p5 (unless Movies Anywhere or BCORE) due to higher bitrate. I think a P8 Movies Anywhere is somewhere between a P8 UHD Remux and a P8 UHD Encode/Hybrid Encode. (Haven't seen a lot of p5 MA releases so haven't given them much thought)
Trees
Post by Trees » Sat Jan 24, 2026 8:43 pm
safariff wrote: Sat Jan 24, 2026 7:23 am
IMDB                                     : tt0240772
TMDB                                     : movie/161
Purely in terms of HDR, I believe a P5 will always be better than any P8, BD remux or VoD WEB-DL. Purely because they (P5) retain more dynamic range than P8 due to their more efficient colour space.
Except when it comes to ATVP/iT content, apparently the colours in Apple-sourced content looks distorted, something to do with the static colour reshaping metadata.
See here:
RESET_9999 wrote: Sun Oct 13, 2024 12:54 pm thats apple stupid static color reshaping. All their DV contents have this difference: red always looks brighter/orangish. sometimes it's less apparent.
this static metadata is removed when you convert the rpu to P8. Apple has no respect to the creator's intent, I did a video about it on my youtube channel.
Never watch iTunes P5 web-dl if you care about accuracy, always convert it to P8.
I'm not quite sure what exactly causes this or what the difference looks like as I haven't really looked into it as I try to avoid Apple-sources content for said reason.
Perhaps reset could can comment in little more detail on this?
Post by RESET_9999 » Sat Jan 24, 2026 9:45 pm
Trees wrote: Sat Jan 24, 2026 8:43 pm I'm not quite sure what exactly causes this or what the difference looks like as I haven't really looked into it as I try to avoid Apple-sources content for said reason.
mostly noticeable with orangish-looking reds.
https://slow.pics/c/0WHpdnDa?canvas-mode=fit-height
https://slow.pics/c/FmvhrI2F?canvas-mod ... it=contain
LV8HD
Post by LV8HD » Mon Jan 26, 2026 3:20 pm
@RESET_9999 given this:
UHD Blu-ray Dolby Vision MEL
Since L2 trims are not static, what is the best practice here: generating new metadata or keeping retail RPU?
