ASUS BW-16D1X-U - Flashable?
Soldi5k
Re: ASUS BW-16D1X-U - Flashable?
Post by Soldi5k »
Hello,, I bought this drive, how could I flash it?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL120185WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
Thanks in advance
Soldi5k wrote: Tue Jan 13, 2026 5:19 pm Hello,, I bought this drive, how could I flash it?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance
Yes it can be made to do UHD email me that drive info see below
pastym
Post by pastym »
Billycar11 wrote: Tue Jan 13, 2026 11:25 pm Yes it can be made to do UHD email me that drive info see below
I also have this drive and would like to flash it.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
pastym wrote: Thu Jan 15, 2026 1:51 am
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
sure just email me that info we are not supposed to do it here
see below
carlsefni
Post by carlsefni »
carlsefni wrote: Fri Dec 26, 2025 8:24 pm
Coopervid wrote: Fri Dec 26, 2025 8:16 pm You can go for it.
Great, thanks. I'll give it a go. At least I am reasonably familiar with the flashing process at this point! :lol:
Just to follow up, I finally received the drive (an LG BP60NB10), flashed it, and it seems to be ripping 4k just fine. Thanks! :D
Szary Kot
Post by Szary Kot »
Hello, I am considering buying a new Asus BW-16D1X-U. I'd like some tips. How to find out before buying that the drive can be flashed? Will information about the year of production help? Is information about the year of release or firmware version necessary before purchasing? Will the appropriate firmware be released by December 2022? Please help.
Licensed User MakeMKV
Szary Kot wrote: Thu Jan 15, 2026 11:45 pm Hello, I am considering buying a new Asus BW-16D1X-U. I'd like some tips. How to find out before buying that the drive can be flashed? Will information about the year of production help? Is information about the year of release or firmware version necessary before purchasing? Will the appropriate firmware be released by December 2022? Please help.
You can't find anything out until you have it in hand and can post the MakeMKV drive info and libredrive info sections. They either use a Pioneer (firmware on it should be pre 12/2022) or LG drive inside and both should be able to be flashed.
Szary Kot
Post by Szary Kot »
Thank you for your comprehensive answer.
amrit35
Post by amrit35 »
Hi all.
Below is the information on the drive i bought. Does the below mean i don't need to flash it and its already enabled by default ?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
amrit35 wrote: Sun Jan 18, 2026 8:35 pm Hi all.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Libredrive is enabled so is good for standard blu-ray. It cannot read UHD discs until you get it cross-flashed to a UHD model Pioneer. Contact Billycar11.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Walkamo
Post by Walkamo »
Hi Everyone,
I have been using this drive for a few years for Blu-ray's, however would like to now use it for UHD discs. Can someone help with updating the firmware? Right now it just says this disc is not supported.
Here are the details of the drive.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Firmware date: 2018-01-15
Drive platform: RS8600
Firmware version: E102/ID76
Thanks,
Walkamo
Mars.X
Post by Mars.X »
Hello! I also have this external drive and i would like to flash it for UHD.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 19
Thanks for your help!
Mars.X
Walkamo wrote: Mon Jan 19, 2026 5:53 pm Hi Everyone,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Thanks,
Walkamo
sure email me that drive info section see below for email
KidJoe
Post by KidJoe »
So those getting a Pioneer drive inside when purchasing the Asus BW-16D1X-U, where are you purchasing them from?
