I bought a what I believed to be a BU40N
However I have my doubts
Drive Information is as follows from MakeMKV
OS device name: I:
Manufacturer: 000000
Product: 9999999999999999
Revision: 1.05
Serial number: MO9P5OG1000
Highest AACS version: 75
Its connected using the recommended cable from Amazon the cablecc one
Says its a Hitachi LG BU40N on the label but it also has this
MSIP-REM-HLD-BU40N
Which would seem to confirm that its meant to be a BU40N
It also doesn't show up in explorer
Questions are have I been duped
Can it be flashed
Or do I hide it from the wife and buy another one that's genuine
Weird UHD drive Information
Re: Weird UHD drive Information
You left out the libredrive info section but it's probably the adapter you are using. Never heard of a cablecc one.Rabster wrote: Thu Jan 15, 2026 5:20 pm I bought a what I believed to be a BU40N
OS device name: I:
Revision: 1.05
MSIP-REM-HLD-BU40N
Can it be flashed
Rabster
There was no libre drive information whatsoever, the cablecc adapter is the one that the link on one of the replies in another thread. What cable would you recommend? TIA
Whatever is in the ultimate UHD drive guide 2026.Rabster wrote: Thu Jan 15, 2026 9:18 pm There was no libre drive information whatsoever, the cablecc adapter is the one that the link on one of the replies in another thread. What cable would you recommend? TIA
On the occasion that I needed to flash a bare BU40N, I used my Alxum powered SATA to USB adapter with a SATA to slimline SATA adapter.
BDR_UD03
One way to confirm is an issue with the cable your are using is to check that serial number matches what is printed on your drive. Does it match?
With LG drives, the serial shown in MakeMKV never matches the label.BDR_UD03 wrote: Mon Jan 26, 2026 12:55 am One way to confirm is an issue with the cable your are using is to check that serial number matches what is printed on your drive. Does it match?
BDR_UD03
Thanks for the info.MartyMcNuts wrote: Mon Jan 26, 2026 6:24 amWith LG drives, the serial shown in MakeMKV never matches the label.BDR_UD03 wrote: Mon Jan 26, 2026 12:55 am One way to confirm is an issue with the cable your are using is to check that serial number matches what is printed on your drive. Does it match?
Mathismath
Have you solved that problem?
I have the same issue?
Can it works or dumps perfectly?
Revision: GF00
Serial number: KZ6GCGI5904
Firmware date: 2116-12-09 14:58
Bus encryption flags: 1F
btw im using mac
Revision: GF00
btw im using mac
no idea if it will work butMathismath wrote: Sun Mar 29, 2026 8:40 am Have you solved that problem?
Revision: GF00
btw im using mac
yeah i can say i am sick of these junk adapters makes flashing impossible and libredrive because it blocks drive info
might still work for regular bluray
i can say only get a approved adapter from the guide i keep it updated if they change the chip set i remove it once i know
OneDay
I bought this adapter from Amazon that was recommended here on MakeMKV
BENFEI SATA to USB 3.0 Cable, USB 3.0 to SATA III Hard Drive Adapter Compatible for 2.5 3.5 Inch HDD/SSD Hard Drive Disk with 12V/2A Power Adapter, Support UASP
So far it's worked with both LG and Pioneer drives showing correct info. Also used to flash both.
Mathismath
Problem solved, just change a cable or adapter is OK.Mathismath wrote: Sun Mar 29, 2026 8:40 am Have you solved that problem?
Revision: GF00
btw im using mac
Thanks for reply.
