Hello,, I bought this drive, how could I flash it?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL120185WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
Thanks in advance
ASUS BW-16D1X-U - Flashable?
Re: ASUS BW-16D1X-U - Flashable?
Yes it can be made to do UHD email me that drive info see belowSoldi5k wrote: Tue Jan 13, 2026 5:19 pm Hello,, I bought this drive, how could I flash it?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance
pastym
I also have this drive and would like to flash it.Billycar11 wrote: Tue Jan 13, 2026 11:25 pm Yes it can be made to do UHD email me that drive info see below
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
sure just email me that info we are not supposed to do it herepastym wrote: Thu Jan 15, 2026 1:51 amI also have this drive and would like to flash it.Billycar11 wrote: Tue Jan 13, 2026 11:25 pm Yes it can be made to do UHD email me that drive info see below
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
see below
carlsefni
Just to follow up, I finally received the drive (an LG BP60NB10), flashed it, and it seems to be ripping 4k just fine. Thanks!
Szary Kot
Hello, I am considering buying a new Asus BW-16D1X-U. I'd like some tips. How to find out before buying that the drive can be flashed? Will information about the year of production help? Is information about the year of release or firmware version necessary before purchasing? Will the appropriate firmware be released by December 2022? Please help.
Licensed User MakeMKV
You can't find anything out until you have it in hand and can post the MakeMKV drive info and libredrive info sections. They either use a Pioneer (firmware on it should be pre 12/2022) or LG drive inside and both should be able to be flashed.Szary Kot wrote: Thu Jan 15, 2026 11:45 pm Hello, I am considering buying a new Asus BW-16D1X-U. I'd like some tips. How to find out before buying that the drive can be flashed? Will information about the year of production help? Is information about the year of release or firmware version necessary before purchasing? Will the appropriate firmware be released by December 2022? Please help.
Szary Kot
amrit35
Hi all.
Below is the information on the drive i bought. Does the below mean i don't need to flash it and its already enabled by default ?
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Libredrive is enabled so is good for standard blu-ray. It cannot read UHD discs until you get it cross-flashed to a UHD model Pioneer. Contact Billycar11.amrit35 wrote: Sun Jan 18, 2026 8:35 pm Hi all.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.amrit35 wrote: Sun Jan 18, 2026 8:35 pm Hi all.
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Walkamo
Hi Everyone,
I have been using this drive for a few years for Blu-ray's, however would like to now use it for UHD discs. Can someone help with updating the firmware? Right now it just says this disc is not supported.
Here are the details of the drive.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Firmware date: 2018-01-15
Drive platform: RS8600
Firmware version: E102/ID76
Thanks,
Walkamo
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Thanks,
Walkamo
Mars.X
Hello! I also have this external drive and i would like to flash it for UHD.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 19
Thanks for your help!
Mars.X
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Mars.X
sure email me that drive info section see below for emailWalkamo wrote: Mon Jan 19, 2026 5:53 pm Hi Everyone,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number:
Thanks,
Walkamo
KidJoe
So those getting a Pioneer drive inside when purchasing the Asus BW-16D1X-U, where are you purchasing them from?
