BDR 212V UHD Guide
Edkun
Re: BDR 212V UHD Guide
#421 Post by Edkun » Wed Jan 14, 2026 12:04 am
Hi Coopervid!
I'm interested in the firmware to enable UHD support on my drive.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL034841WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 31
Drive platform: RS8F00
Firmware version: 1.00/ID61
Thank you!
#422 Post by Coopervid » Wed Jan 14, 2026 2:17 pm
Edkun wrote: Wed Jan 14, 2026 12:04 am Hi Coopervid!
Revision: 1.00
Thank you!
PM sent.
Unkindpuddle
#423 Post by Unkindpuddle » Thu Jan 15, 2026 1:04 am
Good evening Coopervid.
I am looking to flash my BDR-212V for UHD. Thanks!
OS device name: G:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Highest AACS version: 82
Firmware version: ID06
Edkun
#424 Post by Edkun » Thu Jan 15, 2026 1:22 pm
Coopervid wrote: Wed Jan 14, 2026 2:17 pm
PM sent.
Thank you very much!
I'll flash the drive today, as I need to install Windows on a spare PC, and will report back here as I can't reply to PMs yet.
Sorry for the late reply.
#425 Post by Coopervid » Thu Jan 15, 2026 2:42 pm
Unkindpuddle wrote: Thu Jan 15, 2026 1:04 am Good evening Coopervid.
OS device name: G:
Revision: 1.02
Serial number:
PM sent.
random_potato
#426 Post by random_potato » Fri Jan 16, 2026 10:39 pm
Hello Coopervid! I'm also looking to flash my drive.
OS device name: /dev/sr0 (can use Windows to flash if needed)
Revision: 1.02
Serial number:
Edit: It worked! Thank you!
MusicMan
#427 Post by MusicMan » Sat Jan 17, 2026 3:52 am
Hi Coopervid!
I'm looking to flash my drive as well. :)
Revision: 1.02
Serial number:
#428 Post by Coopervid » Sat Jan 17, 2026 11:34 am
random_potato wrote: Fri Jan 16, 2026 10:39 pm Hello Coopervid! I'm also looking to flash my drive.
Revision: 1.02
Serial number:
PM sent.
Rays1
#429 Post by Rays1 » Sat Jan 17, 2026 10:32 pm
Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Does this drive look like it was flashed already? Is this something you can't tell from looking at the data. I know it just spins up then stops and ejects. Also @billycar11 sent me the auto flasher but I can't get past the part where it says configuration files missing. I suspect that isn't part of what Billy sent me as they must be available here in the database of flash tools and I'm supposed to pull the 3.10 file from there drag and drop??? I don't get it. Please go easy on me I'm not that savvy when it comes to this particular task.
Edkun
#430 Post by Edkun » Sun Jan 18, 2026 12:45 pm
Edkun wrote: Thu Jan 15, 2026 1:22 pm
PM sent.
(...) will report back here (...)
Hi Coopervid!
Following the instructions provided by you, the crossflashing went out flawlessly, and my drive can now read UHD discs.
Once again, thank you very much!
Oh, I've sent you an e-mail.
#431 Post by Coopervid » Sun Jan 18, 2026 1:50 pm
MusicMan wrote: Sat Jan 17, 2026 3:52 am Hi Coopervid!
Revision: 1.02
Serial number:
PM sent.
#432 Post by Coopervid » Sun Jan 18, 2026 1:53 pm
Rays1 wrote: Sat Jan 17, 2026 10:32 pm Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Post your Makemkv info.
#433 Post by Billycar11 » Sun Jan 18, 2026 11:33 pm
Pretty sure I helped you out in the email already correct?
And your all flashed now
MusicMan
#434 Post by MusicMan » Mon Jan 19, 2026 12:32 am
Coopervid wrote: Sun Jan 18, 2026 1:50 pm PM sent.
Thank you!!! It's working now. 8)
nthdgreee
#435 Post by nthdgreee » Sun Jan 25, 2026 7:48 pm
Hi Billycar11
I'm interested in the firmware to enable UHD support on my drive. I would appreciate the help. Thank you.
Revision: 1.01
Serial number: (Redacted)
Firmware date: 2021-07-20
Highest AACS version: 50
Firmware version: 1.01/ID06
