BDR 212V UHD Guide
Edkun
Re: BDR 212V UHD Guide
Post by Edkun »
Hi Coopervid!
I'm interested in the firmware to enable UHD support on my drive.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: AEDL034841WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 31
Drive platform: RS8F00
Firmware version: 1.00/ID61
Thank you!
Edkun wrote:
Wed Jan 14, 2026 12:04 am
Hi Coopervid!
Revision: 1.00
Thank you!
PM sent.
Unkindpuddle
Post by Unkindpuddle »
Good evening Coopervid.
I am looking to flash my BDR-212V for UHD. Thanks!
OS device name: G:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number:
Firmware date: 2022-05-31
Highest AACS version: 82
Firmware version: ID06
Edkun
Post by Edkun »
Coopervid wrote:
Wed Jan 14, 2026 2:17 pm
PM sent.
Thank you very much!
I'll flash the drive today, as I need to install Windows on a spare PC, and will report back here as I can't reply to PMs yet.
Sorry for the late reply.
Unkindpuddle wrote:
Thu Jan 15, 2026 1:04 am
OS device name: G:
Revision: 1.02
Serial number:
PM sent.
random_potato
Post by random_potato »
Hello Coopervid! I'm also looking to flash my drive.
OS device name: /dev/sr0 (can use Windows to flash if needed)
Revision: 1.02
Serial number:
Edit: It worked! Thank you!
MusicMan
Post by MusicMan »
Hi Coopervid!
I'm looking to flash my drive as well. :)
Revision: 1.02
Serial number:
random_potato wrote:
Fri Jan 16, 2026 10:39 pm
Revision: 1.02
Serial number:
PM sent.
Rays1
Post by Rays1 »
Good day gents, I've got the same drive recently and Billy sent me the auto flasher. I've got a couple of questions.
Does this drive look like it was flashed already? Is this something you can't tell from looking at the data. I know it just spins up then stops and ejects. Also @billycar11 sent me the auto flasher but I can't get past the part where it says configuration files missing. I suspect that isn't part of what Billy sent me as they must be available here in the database of flash tools and I'm supposed to pull the 3.10 file from there drag and drop??? I don't get it. Please go easy on me I'm not that savvy when it comes to this particular task.
Edkun
Post by Edkun »
Edkun wrote:
Thu Jan 15, 2026 1:22 pm
PM sent.
(...) will report back here (...)
Hi Coopervid!
Following the instructions provided by you, the crossflashing went out flawlessly, and my drive can now read UHD discs.
Once again, thank you very much!
Oh, I've sent you an e-mail.
MusicMan wrote:
Sat Jan 17, 2026 3:52 am
Hi Coopervid!
Revision: 1.02
Serial number:
PM sent.
Rays1 wrote:
Sat Jan 17, 2026 10:32 pm
Post your Makemkv info.
Pretty sure I helped you out in the email already correct?
And your all flashed now
MusicMan
Post by MusicMan »
Coopervid wrote:
Sun Jan 18, 2026 1:50 pm
PM sent.
Thank you!!! It's working now. 8)
nthdgreee
Post by nthdgreee »
Hi Billycar11
I'm interested in the firmware to enable UHD support on my drive. I would appreciate the help. Thank you.
Revision: 1.01
Serial number: (Redacted)
Firmware date: 2021-07-20
Highest AACS version: 50
Firmware version: 1.01/ID06
