Public KeyDB Disc Submissions
keydb_helper
I see comments like yours repeated quite often and it is absolutely not true.99gagamel wrote: Tue Jan 13, 2026 7:38 am I had only updated the German key.
The Leon key, however, was in the English database.
To be clear: The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys.
The only difference between the two is the language of the disc title, not the disc keys. For example, the English keydb may have an entry like this:
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (YOU ONLY LIVE TWICE) | D | 2012-01-30 ...
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (MAN LEBT NUR ZWEIMAL) | D | 2012-01-30 ...
0x9F553092157C4D13DF4A814FC1F7BF7CD68593E4 = LEON (LEON) | D | 2024-10-10...
The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys. Do not download multiple keydb languages thinking there will be any benefit from a decryption perspective
- Do not submit Stranger Things S2D2, S4D3, or S5D2
FrankGrimes2769
Disc type: UHD
Disc ID: 57aedd8d02e4ec2d93d9298c3e6a37aa51d37ed9
Disc dump filename: MKB20_v77_MARVEL_STUDIOS'_THE_FANTASTIC_FOUR-_FIRST_STEPS_-_ULTRA_HD_7698
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ZgkvHt ... drive_link
Disc dump link: https://drive.google.com/file/d/1GRKEQR ... drive_link
Thanks in advance!
Drive: BD-RE BU40N
Thanks in advance!
Vinthor22
I may be posting too much information It's my first time, thanks in advance.
DISC INFORMATION
Validation Data : F8C59E4FE2E3ED1C7A04A6C9232211A4
Media Key : 155F482AA7ED2DE2E5C1F1D93FC1AE5A
--- Disc Information ---
Disc ID : 0x45C12DDADCA466722388FFF28051449F528F5B05
Volume : FORREST GUMP
Title : Forrest Gump
Date : 2018-03-31
Disc Type : UHD Blu-ray
Encryption Keys:
Media Key : 0x155F482AA7ED2DE2E5C1F1D93FC1AE5A
MKB Version : 61
Encrypted Keys (1):
[1] 0x9A4A711CFC5CD45C73DD6D73D0240E00
KeyDB Status:
Status : not found
Firmware version: 1.03
DISC INFORMATION
Date : 2018-03-31
Encryption Keys:
MKB Version : 61
Encrypted Keys (1):
KeyDB Status:
Status : not found
LawfulJoker
Disc Type: UHD Blu-ray
Disc ID: 0x662827F07B41FE359BB516B74B006B2EA9C2AFFA
Disc dump filename: MKB20_v77_1408_UHD_A5EC
Drive: MOBL3HI4814
Drive firmware: 0.BU10O
LibreDrive Status: Enabled
MKB_RO.inf link: https://gofile.io/d/Wl21M6
Disc dump link: https://gofile.io/d/9mHrHq
Thanks in advance.
Drive: MOBL3HI4814
Thanks in advance.
keydb_helper
FrankGrimes2769 wrote: Tue Jan 13, 2026 8:51 pm Disc type: UHD
Thanks in advance!
Thanks for the submissions Grimey and LawfulJoker, it is great to see new users following the submission template. Your discs have been added to the public keydb.LawfulJoker wrote: Wed Jan 14, 2026 11:48 am Disc Type: UHD Blu-ray
These new disc variants have also been added to the public keydb:
MKB20_v77_1408_-_Director's_Cut_A894
MKB20_v77_1408_-_Theatrical_Cut_A5EC
MKB20_v77_1408_UHD_065C
MKB20_v82_Terrifier_60C6
MKB20_v82_TMNT_3_UHD_4276
keydb_helper
Hey Vinthor22, whenever you see this line in the MakeMKV log it means that LibreDrive has freaked out and your disc dump file is not going to be useful:Vinthor22 wrote: Wed Jan 14, 2026 8:11 am LibreDrive Information
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Well. Use KeyDB_helper to update your keys and don't do it manually. And while you have the program running check your recently unsupported disc with "Disc info" und it will show if the disc is supported now.99gagamel wrote: Tue Jan 13, 2026 7:47 amAll good. It was due to the German key database.If you get backup failed then it is not a decryption issue. More likely that you need to clean the disc.
By backup error, I mean missing key.
This is what Make KV displays as a error before the copying process, and it aborts at the start.
It's not always translated correctly into English.
All good. Leon is working. Thank you very much.
Edit. And by the way SamuriHL just released the new 1.0.2.1. version.
FrankGrimes2769
Thanks for the quick work. It works perfectly now. Awesome & simple way of getting help. Thanks, again!
FootFungus07
Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file:
https://drive.google.com/file/d/1qLyXqH ... sp=sharing
Label: DRAGONFLY_SQUADRON_3D
Timestamp: 2025-12-04 18:53:54
Protection: AACS v82
Data capacity: 44.42 Gb
Disc type: BD-ROM
Number of layers: 2
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Thanks again!
Disc type: BD-ROM
Number of layers: 2
Revision: 1.02
Thanks again!
frameloose
So... My second ASUS BW-16D1HT died last week.
Have now got a Verbatim 43888 (LG BU40N) that i have patched. I don't know if these dumps are valid from that platform, like the ASUS was.
https://drive.google.com/drive/folders/ ... axLWRmwquf
MKB20_v82_Jarhead_3166.tgz
MKB_v82_Big_Bold_Beautiful_Journey,_A_A4D4.tgz
Feedback if they are valid or not are very welcome.
extranet
Has this been sorted? It doesn't seem to be. I have the Italian Eagle pictures version.Browneye9999 wrote: Tue Dec 23, 2025 12:42 amSorry I have now added the relevant .inf files alsoBrowneye9999 wrote: Sun Dec 21, 2025 3:33 am Hello,
Disc dumps for 48hrs, Once Upon a Time in the West and White Christmas.
https://drive.google.com/drive/folders/ ... drive_link
Grover
Crooked Earth Blu-ray (Umberella)
https://drive.usercontent.google.com/uc ... t=download
Label: BD_DAVID5192_CrookedEarth
Timestamp: 2025-11-19 10:26:07
Data capacity: 44.18 Gb
Disc type: BD-ROM
Number of layers: 2
Product: BD-RE BH16NS55
Revision: 1.05
Serial number: KLKL5CE4604
Firmware date: 2120-04-21 10:49
Thanks again!
Disc type: BD-ROM
Number of layers: 2
Revision: 1.05
Thanks again!
Rauthr
Disc type: UHD
Disc ID: 0x34DE282744A78BB62A48A4D4A7F5353B38A709E0
Disc dump filename: MKB20_v61_Blade_Runner_2049_898F
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/12jQFSs ... drive_link
Disc dump link: https://drive.google.com/file/d/1mm7OGL ... sp=sharing
This is my first time on this forum, so please advise if I've made any error. Thank you!
keydb_helper
Hey frameloose, thanks for providing those disc dump files. Your discs have been added to the public keydb. Disc dumps from all drive brands (LG, Asus, Pioneer, and Buffalo) are now supported for the purposes of the public keydb.frameloose wrote: Wed Jan 14, 2026 8:24 pm So... My second ASUS BW-16D1HT died last week.
Welcome to the forum Rauthr. There were no issues with your submission, so grab the latest keydb and you should be able to decrypt your disc.Rauthr wrote: Thu Jan 15, 2026 3:32 am This is my first time on this forum, so please advise if I've made any error. Thank you!
Hey FootFungus07, thanks for remembering the MKB_RO.inf file but I think you forgot the actual disc dump file. Feel free to post it whenever you get a chance.FootFungus07 wrote: Wed Jan 14, 2026 6:52 pm Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file: ...
These four titles have been added to the public keydb:
MKB_v82_BD_DAVID5192_CrookedEarth_4266
All three of the disc dumps provided by Browneye9999 were added to the public keydb on December 22.extranet wrote: Wed Jan 14, 2026 10:18 pm Has this been sorted? It doesn't seem to be. I have the Italian Eagle pictures version.
