Batman Begins 4k UHD / HDR
spac3
Post by spac3 »
First time user...
I've recently purchased some 4k blurays and am having a hard time with volume keys, I haven't been able to find any working solutions to my two movies, however the regular bluray discs that came with work fine which leads me to believe this is something to do solely with the UHD discs.
Here's the dump file, please let me know what else I need to do, or any advice.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Downloading latest HK to C:\.MakeMKV ...
Saved AACS dump file as C:\.MakeMKV/MKB20_v61_Batman_Begins_A24F.tgz
Re: Batman Begins 4k UHD / HDR
This line in your log is important:
MakeMKV tries to download the necessary hashed keys when it needs to decrypt a 4K UHD (and AACS v82 regular blu-rays). That line in your log indicates that there was a failure when it tried to download keys. The server moves around from time to time and is located in Russia. Often people have some kind of 'geo blocking' turned on in their router or firewall that trips them up. Sometimes people's ISP is unhelpfully blocking the request.
The UHD FAQ has an entry about it.
spac3
Post by spac3 »
Any direct advice to help fix this?
I’m a novice, running windows 11 with an xfi gateway, not to say your advice isn’t helpful but there is a lot of info to sift through in UHD FAQ
I'm not sure what you mean by "xfi gateway". Does xfi mean Xfinity/Comcast? In the past, people with Xfinity have had to turn off 'advanced security' to be able to download hashed keys.
https://forum.makemkv.com/forum/viewtopic.php?p=153240#p153240
