I'm trying to rip disc 1 and 2 of Bleach TYBW and I keep getting "The volume key is unknown for this disc - video can't be decrypted
Failed to open disc".
The Disc uses AACS v82. My Drive should be able to decrypt that, but it's having issues.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Highest AACS version: 82
Firmware version: 3.10
Disc Information
Label: Bleach TYBW S3 D1
Timestamp: 2025-10-15 13:27:23
Protection: AACS v82
Data capacity: 45.99 Gb
Disc type: BD-ROM
Number of layers: 2
Any suggestions are greatly appreciated.
Bleach TYBW Part 3
Re: Bleach TYBW Part 3
MKBv82 is a case where you need the decryption key for EVERY DISK, which is why you can't arbitrarily decode them. Submitting your file to svc@makemkv.com is the official way, and sending a copy of the file to the keydb people is an alternative method.
LichLordJay
Thanks for the reply. I've sent my files over to the address you included.
How would I submit my files to the KeyDB people?
See the first post over in the Public KeyDB Disc Submissions thread.LichLordJay wrote: Wed Jan 14, 2026 10:21 pm Thanks for the reply. I've sent my files over to the address you included.
