Looking for help flashing Pioneer BD-RW BDR-S12U
nephiamaldun
Post by nephiamaldun » Fri Jan 09, 2026 11:37 am
Dear makemkv community,
i have a BD-RW BDR-S12U for which i kindly request help and advise to flash / or cross flash a firmware which allows use it with makemkv for uhd disks again.
It worked flawlessly with my old intel cpu with sgx, but now won't anymore with my new amd cpu so i request help here :)
Infos:
Laufwerksinformation
OS-Gerätename: /dev/sr0
Produzent: PIONEER
Produkt: BD-RW BDR-S12U
Revision: 1.03
Serienummer: BDDL007225WL
Firmware-Datum: 2022-10-13
Highest AACS version: 61
Drive platform: RS8F01
Firmware version: 1.03/ID43
There is the status enabled, but it is not working.
I am encountering the "Internal Error 489" and standard flashing methods are blocked by the firmware.
MakeMKV v1.18.2 linux(x64-release) gestartet
Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-S12U 1.03 BDDL007225WL' bei Offset '524288'
Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-S12U 1.03 BDDL007225WL' bei Offset '1048576'
Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-S12U 1.03 BDDL007225WL' bei Offset '34816'
I am running Linux and installed makemkv from AUR in version 1.18.2.
I have bought a unlimted license key.
Thanks in advance!
Edit: i have written an email @ billycar and hope for a solution regarding the non optimal firmware 1.03.
nephiamaldun
Re: Looking for help flashing Pioneer BD-RW BDR-S12U
Post by nephiamaldun » Tue Jan 13, 2026 7:20 pm
Here are my debug logs. Anyone has an idea? Is it possible to flash down the firmware to something better than Firmware version 1.03/ID43. Normal BR working, 4k BR not.
Thank you and best Wishes.
Debug log started at Tue Jan 13 19:17:43 2026 , written by MakeMKV v1.18.2 linux(x64-release)
001005:0000 MakeMKV v1.18.2 linux(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als file:///home/steff/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.18.0/OpenSSL/3.6.0/1.68.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at [$&!cPHsNoNC,vJT%<05$ :29393631
SDF  v0a4: PIONEER_BD-RW___BDR-S12U_1.03_BDDL007225WL
001003:0020 DEBUG: Code 4278534144 at R}5I(mqyj*Y)l/y0L:121264878
DEBUG: Code 0 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 1 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 2 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 3 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 4 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 5 at R}5I(mqyj*Y)l/y0L:213132882
DEBUG: Code 0 at R}5I(mqyj*Y)l/y0L:213133181
DEBUG: Code 0 at ]&o3!%rA'3D+VNk8:213136746
001003:0020 DEBUG: Code 512 at (Rp2mO {WbC9Yum*zR :213133480
001003:0020 DEBUG: Code 117572073 at ?W)*ZiARl.`gQC`mvo:29394459
001003:0020 DEBUG: Code 117572073 at ?W)*ZiARl.`gQC`mvo:121263429
001003:0020 DEBUG: Code 117572073 at ?W)*ZiARl.`gQC`mvo:121262302
002003:0000 Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW   BDR-S12U 1.03 BDDL007225WL' bei Offset '524288'
001003:0020 DEBUG: Code 1024 at (Rp2mO {WbC9Yum*zR :213133480
002003:0000 Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW   BDR-S12U 1.03 BDDL007225WL' bei Offset '1048576'
001003:0020 DEBUG: Code 34 at (Rp2mO {WbC9Yum*zR :213133480
002003:0000 Fehler 'Interner Fehler - Eingabeparameter ist falsch (489)' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW   BDR-S12U 1.03 BDDL007225WL' bei Offset '34816'
001003:0020 DEBUG: Code 0 at &w\Pqo<4Ad[}vI'%Bjk:121261773
Post by MartyMcNuts » Wed Jan 14, 2026 1:42 am
Infos:
Produzent: PIONEER
Revision: 1.03
Thanks in advance!
Your issue is not firmware related. Your drive is UHD compatible and libredrive enabled. Nothing to be done with the drive. Try going back to older version of MakeMKV. Most Linux users use v1.17.7
nephiamaldun
Post by nephiamaldun » Wed Jan 14, 2026 7:34 pm
Dear Marty,
i was not able to downgrad to this very old 1.17.7 cause of dependency hell, especially to new ffmpeg etc.
Is there any other workaround anyone can kindly suggest or will this be fixed in an upcoming version perhaps? :-)
Do a lot of Linux folk have this problem at the moment? I found this: viewtopic.php?t=37670
Post by MartyMcNuts » Wed Jan 14, 2026 10:19 pm
Dear Marty,
You would probably be better off asking in the Linux threads but I can say for sure that your issue is not firmware related so whatever you do, DO NOT flash/edit/update the firmware on your drive.
And yes, v1.18.2 has been an issue for many Linux users. Many have reported success when going back to v1.17.7.
