zittrig
#316
Post
by zittrig » Wed Dec 17, 2025 7:19 pm
Coopervid wrote: Wed Dec 17, 2025 6:32 pm
zittrig wrote: Wed Dec 17, 2025 5:36 pm
Little big problem with a 43890 with Pioneer BDR-UD03 .....
Power outage while flashing process .... I was flashing the drive for a friend and I always testing by using all cables. Power cable connection included.
A few seconds after starting the flashing process power is gone. Notebook worked with accu and the Y-Power-Cable was connected also. But without electric power the flashing process was interrupted and the drive now is not usable.
Is it bricked? Or can I rescue it?
Don't know. It should be most likely in kernel mode. Just run the Flasher and check. Report back.
The situation was the tray wouldn't open, the power LED was lit and Windows Explorer only recognized the drive as a CD drive. Your flashing tool stopped at "Enumerating drives ....1" and didn't recognize the drive.
Buuuut: I only had to wait a bit longer and the flashing tool recognized the drive at last. Flashing process successful!
Thanks to you a lot!
#317
Post
by Coopervid » Wed Dec 17, 2025 7:22 pm
zittrig wrote: Wed Dec 17, 2025 7:19 pm
Very happy to hear that! Glad I could help!
slapdaddy
#318
Post
by slapdaddy » Mon Dec 22, 2025 12:13 am
If this is the wrong thread, please delete this, I posted in the BDR-UD03 thread where I believe this post should have been.
@Coopervid
Ugh, my LG burner just ate it and I grabbed a Verbatim 43890 from Office Depot.. looks like it's compatible though!
Drive info:
OS device name: O:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Can you provide help with flashing? Thanks for all you do!
#319
Post
by Coopervid » Mon Dec 22, 2025 5:09 pm
slapdaddy wrote: Mon Dec 22, 2025 12:13 am
@Coopervid
Drive info:
OS device name: O:
Revision: 1.14
Serial number:
PM sent.
slapdaddy
#320
Post
by slapdaddy » Tue Dec 23, 2025 12:50 am
Coopervid wrote: Mon Dec 22, 2025 5:09 pm
@Coopervid
Drive info:
OS device name: O:
Revision: 1.14
Serial number:
PM sent.
Very simple and straight forward! Thank you very much!
wampachow
#321
Post
by wampachow » Tue Dec 23, 2025 4:34 pm
Hello! Long time MakeMKV user, but first time disc-drive flasher. I'm on a Mac and read through the instructions, the first being I need to be running v1.17.7 or older. I tried downgrading (and I deleted the MakeMKV folder in the library), but when I try opening, I get "Fatal Error Occurred." I don't want to brick my new drive, so I appreciate the help!
Revision: 1.14
Serial number: DDDL525202WL
#322
Post
by Coopervid » Tue Dec 23, 2025 5:15 pm
wampachow wrote: Tue Dec 23, 2025 4:34 pm
Revision: 1.14
Oh boy! You are completely detour! Flashing this drive is not possible with the tools in the forum. I will send you a PM with the correct tool and files. You need to connect your drive to a Windows PC or install a Windows VM ( preferrably VMWare).
Temha58
#323
Post
by Temha58 » Mon Jan 05, 2026 11:12 pm
Hi!
I have the same drive (Verbatim 43890) and luckily came across this forum post.
Would you be kind enough to provide me the files I need for flashing?
Revision: 1.14
Serial number: xxx
Highest AACS version: 36
Thank you very much.
M_T_J
#324
Post
by M_T_J » Wed Jan 07, 2026 12:02 am
__________________________________
OS device name: F:
Revision: 1.14
Serial number: CIDL503556WL
Highest AACS version: 66
Just recently received this same drive. I didn't know this would not read/rip UHD's.
I would like for this to rip/read UHD's if possible.
Currently running Windows OS
Thank you in advance
wolviak
#325
Post
by wolviak » Wed Jan 07, 2026 2:00 am
@Coopervid
I also picked up a 43890 with a pioneer drive, can I get help flashing it?
Thank You
#326
Post
by Billycar11 » Wed Jan 07, 2026 12:55 pm
M_T_J wrote: Wed Jan 07, 2026 12:02 am
OS device name: F:
Revision: 1.14
Temha58 wrote: Mon Jan 05, 2026 11:12 pm
Hi!
Revision: 1.14
Serial number: xxx
Both of you email me that drive info section see below for email
M_T_J
#327
Post
by M_T_J » Sun Jan 11, 2026 8:09 am
Billycar11 wrote: Wed Jan 07, 2026 12:55 pm
I want to thank you for the help with this. Your flasher worked flawless and I was able to rip a UHD disk.
Amon42
#328
Post
by Amon42 » Tue Jan 13, 2026 1:54 pm
Hi there, I also want to flash my drive (info below) can you send me the instructions?
I also have an additional question: I already used the drive quite a lot and never had any issues but for a short while I now get the error message "Please insert disk" when swapping to a new DVD, unless I disconnect and reconnect the drive and restart MakeMKV, is this something that can be fixed in any way or is it just a Windows issue?
Thanks in advance for your support.
OS device name: \Device\CdRom4
Current profile: DVD-ROM
Revision: 1.14
Serial number:
Highest AACS version: 81
pradogx
#329
Post
by pradogx » Tue Jan 13, 2026 8:21 pm
@Coopervid
I also purchased a Verbatim 43890 and would like to enable UHD reading on it. I would greatly appreciate your help with this when you get a moment. Thank you!
Here is the drive info:
Revision: 1.14
Serial number: xxxxxxxxxxxx
Highest AACS version: 68
pradogx on Fri Jan 23, 2026 2:16 am, edited 2 times in total.
#330
Post
by Billycar11 » Tue Jan 13, 2026 11:28 pm
Amon42 wrote: Tue Jan 13, 2026 1:54 pm
Revision: 1.14
Serial number:
This won't fix that issue you likely have a power issue
But if you want it to do UHD email me that drive info see below
