Public KeyDB Disc Submissions
ex_libris
#1546 Post by ex_libris » Tue Jan 13, 2026 9:51 am
Link to dumpfile for MKB_v82_TCAB_287_5A20
https://drive.google.com/file/d/1_fEIql ... share_link
keydb_helper
#1547 Post by keydb_helper » Tue Jan 13, 2026 12:55 pm
99gagamel wrote: Tue Jan 13, 2026 7:38 am I had only updated the German key.
The Leon key, however, was in the English database.
I see comments like yours repeated quite often and it is absolutely not true.
To be clear: The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys.
The only difference between the two is the language of the disc title, not the disc keys. For example, the English keydb may have an entry like this:
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (YOU ONLY LIVE TWICE) | D | 2012-01-30 ...
whereas the German keydb will have a functionally equivalent entry like this:
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (MAN LEBT NUR ZWEIMAL) | D | 2012-01-30 ...
For your particular disc, the entry is actually identical between the English and German keydb files:
0x9F553092157C4D13DF4A814FC1F7BF7CD68593E4 = LEON (LEON) | D | 2024-10-10...
The issue you observed was because you hadn't downloaded the latest keydb file before trying to decrypt your disc. If I post that a disc has been added to the keydb, it means it has just been added and you will need to sync or re-download the keydb before you'll see any benefit.
The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys. Do not download multiple keydb languages thinking there will be any benefit from a decryption perspective
KeyDB Download
FrankGrimes2769
#1548 Post by FrankGrimes2769 » Tue Jan 13, 2026 8:51 pm
Disc type: UHD
Disc ID: 57aedd8d02e4ec2d93d9298c3e6a37aa51d37ed9
Disc dump filename: MKB20_v77_MARVEL_STUDIOS'_THE_FANTASTIC_FOUR-_FIRST_STEPS_-_ULTRA_HD_7698
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ZgkvHt ... drive_link
Disc dump link: https://drive.google.com/file/d/1GRKEQR ... drive_link
Thanks in advance!
Vinthor22
#1549 Post by Vinthor22 » Wed Jan 14, 2026 8:11 am
I may be posting too much information It's my first time, thanks in advance.
DISC INFORMATION
Validation Data : F8C59E4FE2E3ED1C7A04A6C9232211A4
Media Key : 155F482AA7ED2DE2E5C1F1D93FC1AE5A
--- Disc Information ---
Disc ID : 0x45C12DDADCA466722388FFF28051449F528F5B05
Volume : FORREST GUMP
Title : Forrest Gump
Date : 2018-03-31
Disc Type : UHD Blu-ray
Encryption Keys:
Media Key : 0x155F482AA7ED2DE2E5C1F1D93FC1AE5A
MKB Version : 61
Encrypted Keys (1):
[1] 0x9A4A711CFC5CD45C73DD6D73D0240E00
KeyDB Status:
Status : not found
Firmware version: 1.03
LawfulJoker
#1550 Post by LawfulJoker » Wed Jan 14, 2026 11:48 am
Disc Type: UHD Blu-ray
Disc ID: 0x662827F07B41FE359BB516B74B006B2EA9C2AFFA
Disc dump filename: MKB20_v77_1408_UHD_A5EC
Drive: MOBL3HI4814
Drive firmware: 0.BU10O
LibreDrive Status: Enabled
MKB_RO.inf link: https://gofile.io/d/Wl21M6
Disc dump link: https://gofile.io/d/9mHrHq
Thanks in advance.
keydb_helper
#1551 Post by keydb_helper » Wed Jan 14, 2026 1:51 pm
FrankGrimes2769 wrote: Tue Jan 13, 2026 8:51 pm Disc type: UHD
Thanks in advance!
LawfulJoker wrote: Wed Jan 14, 2026 11:48 am Disc Type: UHD Blu-ray
Thanks for the submissions Grimey and LawfulJoker, it is great to see new users following the submission template. Your discs have been added to the public keydb.
These new disc variants have also been added to the public keydb:
MKB20_v77_1408_-_Director's_Cut_A894
MKB20_v77_1408_-_Theatrical_Cut_A5EC
MKB20_v77_1408_UHD_065C
MKB20_v82_Terrifier_60C6
MKB20_v82_TMNT_3_UHD_4276
KeyDB Download
keydb_helper
#1552 Post by keydb_helper » Wed Jan 14, 2026 2:10 pm
Vinthor22 wrote: Wed Jan 14, 2026 8:11 am LibreDrive Information
Hey Vinthor22, whenever you see this line in the MakeMKV log it means that LibreDrive has freaked out and your disc dump file is not going to be useful:
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Power cycle your drive, shutdown your computer, delete the disc dump file and try again.
KeyDB Download
#1553 Post by Coopervid » Wed Jan 14, 2026 2:32 pm
99gagamel wrote: Tue Jan 13, 2026 7:47 am
If you get backup failed then it is not a decryption issue. More likely that you need to clean the disc.
All good. It was due to the German key database.
By backup error, I mean missing key.
This is what Make KV displays as a error before the copying process, and it aborts at the start.
It's not always translated correctly into English.
:-) All good. Leon is working. Thank you very much.
Well. Use KeyDB_helper to update your keys and don't do it manually. And while you have the program running check your recently unsupported disc with "Disc info" und it will show if the disc is supported now.
Edit. And by the way SamuriHL just released the new 1.0.2.1. version.
FrankGrimes2769
#1554 Post by FrankGrimes2769 » Wed Jan 14, 2026 2:34 pm
Thanks for the quick work. It works perfectly now. Awesome & simple way of getting help. Thanks, again!
FootFungus07
#1555 Post by FootFungus07 » Wed Jan 14, 2026 6:52 pm
Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file:
https://drive.google.com/file/d/1qLyXqH ... sp=sharing
Label: DRAGONFLY_SQUADRON_3D
Timestamp: 2025-12-04 18:53:54
Protection: AACS v82
Data capacity: 44.42 Gb
Disc type: BD-ROM
Number of layers: 2
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Thanks again!
frameloose
#1556 Post by frameloose » Wed Jan 14, 2026 8:24 pm
So... My second ASUS BW-16D1HT died last week.
Have now got a Verbatim 43888 (LG BU40N) that i have patched. I don't know if these dumps are valid from that platform, like the ASUS was.
https://drive.google.com/drive/folders/ ... axLWRmwquf
MKB20_v82_Jarhead_3166.tgz
MKB_v82_Big_Bold_Beautiful_Journey,_A_A4D4.tgz
Feedback if they are valid or not are very welcome.
extranet
#1557 Post by extranet » Wed Jan 14, 2026 10:18 pm
Browneye9999 wrote: Tue Dec 23, 2025 12:42 am
Browneye9999 wrote: Sun Dec 21, 2025 3:33 am Hello,
Disc dumps for 48hrs, Once Upon a Time in the West and White Christmas.
https://drive.google.com/drive/folders/ ... drive_link
Sorry I have now added the relevant .inf files also
Has this been sorted? It doesn't seem to be. I have the Italian Eagle pictures version.
Grover
#1558 Post by Grover » Thu Jan 15, 2026 12:00 am
Crooked Earth Blu-ray (Umberella)
https://drive.usercontent.google.com/uc ... t=download
Label: BD_DAVID5192_CrookedEarth
Timestamp: 2025-11-19 10:26:07
Data capacity: 44.18 Gb
Disc type: BD-ROM
Number of layers: 2
Product: BD-RE BH16NS55
Revision: 1.05
Serial number: KLKL5CE4604
Firmware date: 2120-04-21 10:49
Thanks again!
Rauthr
#1559 Post by Rauthr » Thu Jan 15, 2026 3:32 am
Disc type: UHD
Disc ID: 0x34DE282744A78BB62A48A4D4A7F5353B38A709E0
Disc dump filename: MKB20_v61_Blade_Runner_2049_898F
Drive: PIONEER BDR-BDS8
Drive firmware: 1.01/ID05
MKB_RO.inf link: https://drive.google.com/file/d/12jQFSs ... drive_link
Disc dump link: https://drive.google.com/file/d/1mm7OGL ... sp=sharing
This is my first time on this forum, so please advise if I've made any error. Thank you!
keydb_helper
#1560 Post by keydb_helper » Thu Jan 15, 2026 11:58 am
frameloose wrote: Wed Jan 14, 2026 8:24 pm So... My second ASUS BW-16D1HT died last week.
Hey frameloose, thanks for providing those disc dump files. Your discs have been added to the public keydb. Disc dumps from all drive brands (LG, Asus, Pioneer, and Buffalo) are now supported for the purposes of the public keydb.
Rauthr wrote: Thu Jan 15, 2026 3:32 am This is my first time on this forum, so please advise if I've made any error. Thank you!
Welcome to the forum Rauthr. There were no issues with your submission, so grab the latest keydb and you should be able to decrypt your disc.
FootFungus07 wrote: Wed Jan 14, 2026 6:52 pm Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file: ...
Hey FootFungus07, thanks for remembering the MKB_RO.inf file but I think you forgot the actual disc dump file. Feel free to post it whenever you get a chance.
These four titles have been added to the public keydb:
MKB_v82_BD_DAVID5192_CrookedEarth_4266
extranet wrote: Wed Jan 14, 2026 10:18 pm Has this been sorted? It doesn't seem to be. I have the Italian Eagle pictures version.
All three of the disc dumps provided by Browneye9999 were added to the public keydb on December 22.
KeyDB Download
