Public KeyDB Disc Submissions
99gagamel
Post by 99gagamel »
Coopervid wrote:
Mon Jan 12, 2026 3:23 pm
99gagamel wrote:
Mon Jan 12, 2026 2:53 pm
The following new UHD titles have been added to the public keydb: Leon
Unfortunately, the title cannot be deciphered. The key on my disc is different.
Attached is information about the new Steelbook UHD
Disc type: UHD
Disc ID: E064BA3E3F81
Disc dump filename: MKB20_v77_LEON_5149.tgz
Drive:BW-1601HT
Drive firmware:3.01
LibreDrive status:Activated
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf https://drive.google.com/file/d/1jAvoQW ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1pEJwDv ... sp=sharing
Man! Since you are running Windows - just use KeyDB_helper.exe to update your KeyDB and don't post unneccesary files.
Hello, that was a very unfriendly response.
This thread is for helping each other. We should be nice and polite, especially considering that everyone's experience is different.
Yes, the key is up to date, and yes, it always preloads for me, and I've been posting a lot of dumps correctly for a long time.
Apparently, the problem lies elsewhere. Everything is updated. Nevertheless, MKV still displays "Backup Failed"!
Best greets
99gagamel wrote:
Tue Jan 13, 2026 7:19 am
Disc type: UHD
Drive:BW-1601HT
Drive firmware:3.01
Best greets
If you get backup failed then it is not a decryption issue. More likely that you need to clean the disc.
99gagamel
Post by 99gagamel »
I usually replace the keys myself.
But the information that I should try again with Key Helper was helpful.
I found the problem.
I had only updated the German key.
The Leon key, however, was in the English database.
Thank you very much.
Leon is working.
Best greets
99gagamel
Post by 99gagamel »
All good. It was due to the German key database.
By backup error, I mean missing key.
This is what Make KV displays as a error before the copying process, and it aborts at the start.
It's not always translated correctly into English.
:-) All good. Leon is working. Thank you very much.
ex_libris
Post by ex_libris »
Link to dumpfile for MKB_v82_TCAB_287_5A20
https://drive.google.com/file/d/1_fEIql ... share_link
keydb_helper
Post by keydb_helper »
99gagamel wrote:
Tue Jan 13, 2026 7:38 am
I see comments like yours repeated quite often and it is absolutely not true.
To be clear: The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys.
The only difference between the two is the language of the disc title, not the disc keys. For example, the English keydb may have an entry like this:
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (YOU ONLY LIVE TWICE) | D | 2012-01-30 ...
whereas the German keydb will have a functionally equivalent entry like this:
0x33992FFBCCFF2E87BEAEF55C421D780BB8BA0861 = YOU ONLY LIVE TWICE (MAN LEBT NUR ZWEIMAL) | D | 2012-01-30 ...
For your particular disc, the entry is actually identical between the English and German keydb files:
0x9F553092157C4D13DF4A814FC1F7BF7CD68593E4 = LEON (LEON) | D | 2024-10-10...
The issue you observed was because you hadn't downloaded the latest keydb file before trying to decrypt your disc. If I post that a disc has been added to the keydb, it means it has just been added and you will need to sync or re-download the keydb before you'll see any benefit.
The keys within the different keydb language variants are exactly the same. There is no need to download multiple languages of the keydb file. They all have the same keys. Do not download multiple keydb languages thinking there will be any benefit from a decryption perspective
FrankGrimes2769
Post by FrankGrimes2769 »
Disc type: UHD
Disc ID: 57aedd8d02e4ec2d93d9298c3e6a37aa51d37ed9
Disc dump filename: MKB20_v77_MARVEL_STUDIOS'_THE_FANTASTIC_FOUR-_FIRST_STEPS_-_ULTRA_HD_7698
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.google.com/file/d/1ZgkvHt ... drive_link
Disc dump link: https://drive.google.com/file/d/1GRKEQR ... drive_link
Thanks in advance!
Vinthor22
Post by Vinthor22 »
I may be posting too much information It's my first time, thanks in advance.
DISC INFORMATION
Validation Data : F8C59E4FE2E3ED1C7A04A6C9232211A4
Media Key : 155F482AA7ED2DE2E5C1F1D93FC1AE5A
--- Disc Information ---
Disc ID : 0x45C12DDADCA466722388FFF28051449F528F5B05
Volume : FORREST GUMP
Title : Forrest Gump
Date : 2018-03-31
Disc Type : UHD Blu-ray
Encryption Keys:
Media Key : 0x155F482AA7ED2DE2E5C1F1D93FC1AE5A
MKB Version : 61
Encrypted Keys (1):
[1] 0x9A4A711CFC5CD45C73DD6D73D0240E00
KeyDB Status:
Status : not found
Firmware version: 1.03
LawfulJoker
Post by LawfulJoker »
Disc Type: UHD Blu-ray
Disc ID: 0x662827F07B41FE359BB516B74B006B2EA9C2AFFA
Disc dump filename: MKB20_v77_1408_UHD_A5EC
Drive: MOBL3HI4814
Drive firmware: 0.BU10O
LibreDrive Status: Enabled
MKB_RO.inf link: https://gofile.io/d/Wl21M6
Disc dump link: https://gofile.io/d/9mHrHq
Thanks in advance.
keydb_helper
FrankGrimes2769 wrote:
Tue Jan 13, 2026 8:51 pm
Disc type: UHD
Thanks in advance!
LawfulJoker wrote:
Wed Jan 14, 2026 11:48 am
Thanks for the submissions Grimey and LawfulJoker, it is great to see new users following the submission template. Your discs have been added to the public keydb.
These new disc variants have also been added to the public keydb:
MKB20_v77_1408_-_Director's_Cut_A894
MKB20_v77_1408_-_Theatrical_Cut_A5EC
MKB20_v77_1408_UHD_065C
MKB20_v82_Terrifier_60C6
MKB20_v82_TMNT_3_UHD_4276
keydb_helper
Vinthor22 wrote:
Wed Jan 14, 2026 8:11 am
Hey Vinthor22, whenever you see this line in the MakeMKV log it means that LibreDrive has freaked out and your disc dump file is not going to be useful:
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Power cycle your drive, shutdown your computer, delete the disc dump file and try again.
99gagamel wrote:
Tue Jan 13, 2026 7:47 am
Well. Use KeyDB_helper to update your keys and don't do it manually. And while you have the program running check your recently unsupported disc with "Disc info" und it will show if the disc is supported now.
Edit. And by the way SamuriHL just released the new 1.0.2.1. version.
FrankGrimes2769
Thanks for the quick work. It works perfectly now. Awesome & simple way of getting help. Thanks, again!
FootFungus07
Post by FootFungus07 »
Dragonfly Squadron 3D Blu-ray (Bayview Entertainment)
Here's the MKB_RO.inf file:
https://drive.google.com/file/d/1qLyXqH ... sp=sharing
Label: DRAGONFLY_SQUADRON_3D
Timestamp: 2025-12-04 18:53:54
Protection: AACS v82
Data capacity: 44.42 Gb
Disc type: BD-ROM
Number of layers: 2
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03NB8C0638
Firmware date: 2120-05-07 09:35
Thanks again!
frameloose
Post by frameloose »
So... My second ASUS BW-16D1HT died last week.
Have now got a Verbatim 43888 (LG BU40N) that i have patched. I don't know if these dumps are valid from that platform, like the ASUS was.
https://drive.google.com/drive/folders/ ... axLWRmwquf
MKB20_v82_Jarhead_3166.tgz
MKB_v82_Big_Bold_Beautiful_Journey,_A_A4D4.tgz
Feedback if they are valid or not are very welcome.
