Asus BW-16D1X-U
Re: Asus BW-16D1X-U
aitee wrote: Thu Jan 08, 2026 4:32 am Somehow my image did not attach.
Not sure how to get it properly in an image tag or attachment. So I uploaded it here:
https://imgur.com/a/IplDcrm
You don't add attachments here. You should upload somewhere else like you have done.
Why are you showing us the label. It is not relevant. We only need to see the drive info & libredrive info sections from MakeMKV which you have already provided.
Just email in the firmware dump as requested and then you can flash it as I already said.
Assirock
Re: Asus BW-16D1X-U
Post by Assirock »
Hi. I just purchased a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks you
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Firmware version: ID76
Re: Asus BW-16D1X-U
Assirock wrote: Tue Jan 13, 2026 12:11 am Hi. I just purchased a new Asus BW-16D1H-U PRO Can someone help me make it support UHD? Thanks you
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
yes just email me that drive info see below for email
sanumaj
Re: Asus BW-16D1X-U
Post by sanumaj »
Hi Folks
Just recied a new Asus BW-16D1X-U : PIONEER BDR-212T (RS8F00). This is the MakeMKV summary on my BluRay Drive. Reads Blu Ray just fine but 4K UHD is no go. Can you help please? Confused as LibreDrive Status is Enabled...
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127631WL
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: E113/ID76
Thanks in advance!
Re: Asus BW-16D1X-U
sanumaj wrote: Mon Feb 16, 2026 4:15 am Hi Folks
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance!
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
dewille
Re: Asus BW-16D1X-U
Post by dewille »
Hi guys,
If my drive can be flashed to read UHD movies pls let me know. Many thanks
OS device name: /dev/rdisk4
Current profile: BD-RE
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: CKDL103572WL
Disc Information
Label: MAC_BACKUPS_1___PART_3_OF_5
Timestamp: 2010-10-23 18:53:28
Data capacity: 23.30 Gb
Disc type: BD-RE
Number of layers: 1
Re: Asus BW-16D1X-U
dewille wrote: Sat Apr 11, 2026 11:42 am Hi guys,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Disc Information
Disc type: BD-RE
Number of layers: 1
see below for email
sirmeowthius
Re: Asus BW-16D1X-U
Post by sirmeowthius »
Hi, new here. Just wanted to say that this ASUS BW-16D1X-U External (M-Disc Compatible) drive is definitely flashable to the LibreDrive Firmware. Mine was manufactured in 2023, didnt even bother shucking the casing to get to the drive inside.
Backed up the base firmware with the SDFTool Flasher.
Flashed it with - DE_ASUS_BW-16D1HT_3.10_MK.bin
Waited about 10 seconds for it to complete. Turned it off and unplugged the USB.
Rebooted my PC for safe measure.
Then I archived Justice League 4K 2-disc set without issue.
I did do a OmniDrive flash right after to test it out as well, then after that I flashed back to LibreDrive CFW.
What I did notice is that jumping between 4K/UHD and HD Blurays it may cause the drive to hang up and cause I/O read errors. Could be that ive been archiving about 30+ discs today, and that the USB ports on my mobo are like please stop. Full PC shutdown for about 2 minutes cleared that up and I archived about 7 more discs so far since.
Hope this helps putting it on the compatibility list.
Trade_2009
Re: Asus BW-16D1X-U
Post by Trade_2009 »
Good afternoon,
My question is to see if someone could help me. I received the following DVD burner today, and I'd like to know if it's compatible with UHD. If so, what steps should I follow to downgrade the firmware using SDFtool Flasher, and which firmware would be compatible?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial Number: KL6PABE2651
Firmware Date: 2120-12-02 11:14
Bus Encryption Marks: 1F
Highest AACS Version: 82
Drive Platform: MT1959
Thank you in advance.
Re: Asus BW-16D1X-U
Trade_2009 wrote: Mon Aug 10, 2026 1:09 pm Good afternoon,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
sure see guide below or email
me or marty for the auto flasher
that drive can be flashed to do UHD
