PIONEER BDR-212T Flashable?
Hello, I was wondering if this drive was flashable. Any help would be appreciated.
Below are the specifications:
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: PIONEER BDR-212T Flashable?
PM sent.Super Ham wrote: ↑Thu Jan 01, 2026 10:53 pmHello, I was wondering if this drive was flashable. Any help would be appreciated.
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
I have a similar external ASUS drive, so I have the same question.
Please help me with updating the firmware to a UHD reading friendly drive if that is possible.
Thank you very much!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Highest AACS version: 61
Firmware version: E116/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Yeah I can flash it email me the drive info see below for emailhobymankz wrote: ↑Wed Jan 07, 2026 7:54 pmHello,
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Hi there!
I have the same type.
Could i get the fw, too? And how can i patch it myself into the device, is there an patcher included?
Edit: I found the guides and instructions for the flash, i am just curious for the correct FW.
You need to post your Makemkv info if you have a Pioneer drive.
Laufwerksinformation
OS-Gerätename: H:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Serienummer: deleted for obvious reasons
Firmware-Datum: 2020-07-21
Highest AACS version: 68
Keine Disk eingelegt
OS-Gerätename: H:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
PM sent.mortes82 wrote: ↑Mon Jan 12, 2026 3:06 pmLaufwerksinformation
OS-Gerätename: H:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: E113
Thank you, unfortunatelly i can not send you a pn but i send you my appreciations and gratitude.
Hello!
I also have a Asus BW-16D1X-U external with a Pioneer BDR-212T drive inside.
Can i get the patched firmware for this unit, please?
Hello, I also have an external device Asus BW-16D1X-U, with Pioneer BDR-212T inside.
I need a patch for playing 4K Bluray discs. Can you help me, please?
Those are the specifications:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Highest AACS version: 19
BD raw data read:Yes
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
sure email me that drive info section see below for emailMars.X wrote: ↑Mon Jan 19, 2026 5:31 pmHello, I also have an external device Asus BW-16D1X-U, with Pioneer BDR-212T inside.
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
I have ASUS BW-16D1X-U.
Can someone help me to flash it and make it UHD friendly
That particular PN has been used on at least two different drives, so the dump reported by MakeMKV is important to know which software is required.
