Okay, it's not on Linux though
This has nothing to do with MakeMKV. Try contacting MPC-HC support.schnoz wrote: ↑Sun Jan 11, 2026 11:47 amFlashing seems to work, it does take quite a while for my PC to recognize a 4K disc (the 2nd time it sounded like an engine reving up high) and MPC-HC gave me an error about MakeMKV
report information:
Manufacturer Clsid
Application name MPC-HC
Application version 2.6.0.0
Problem state Won't be fixed More info
Problem 710544
Dump group 2665239
Dump 143754961
stack:
libmmbd!aacs_set_fopen+0x15
libbluray!libaacs_open+0x15d
libbluray!dec_init+0x1c1
libbluray!disc_open+0x2f5
libbluray!_bd_open+0x63
libbluray!bd_open+0x79
lavsplitter!CBDDemuxer::Open+0x1e0
lavsplitter!CLAVSplitter::LoadURL+0x2e4
mpc_hc64!CFGManager::AddSourceFilter+0x34b
mpc_hc64!CFGManager::RenderFile+0x164
mpc_hc64!CMainFrame::OpenFile+0x3fb
mpc_hc64!CMainFrame::OpenMediaPrivate+0x345
mpc_hc64!CGraphThread::OnOpen+0x31
mpc_hc64!CWinThread::DispatchThreadMessageEx+0x62
mpc_hc64!AfxInternalPreTranslateMessage+0x29
mpc_hc64!AfxInternalPumpMessage+0x3c
mpc_hc64!CWinThread::Run+0x75
mpc_hc64!_AfxThreadEntry+0x120
mpc_hc64!thread_start<unsigned int (__cdecl*)(void * __ptr64)>+0x5d
kernel32!BaseThreadInitThunk+0x14
ntdll!RtlUserThreadStart+0x21
Hello, I am new on here. I have a drive that cannot read UHD. Can you help me.
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E116/ID71
Drive Informations:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Hello, also new here.
Can't say that flashing is a straightforward process ...
I just got a WP50NB40 ( only drive I could find at my local microcenter )
and after running makeMKV I got the following
and I'm bit confused with the next step
My understanding is that I need to go to
DE_LG_WP50NB40-NB50_1.03_MK.bin
and then to
DE_LG_BP60NB10_1.02-MK.bin
is that the correct assumption ? I did not fully grasp the concept of SVC ( and if it's relevant here )
Any guidance would be much appreciated
Thanks in advance
I got the All You Need Firmware Pack (MartyMcNuts) packManufacturer: HL-DT-ST
Product: BD-RE WP50NB40
Revision: 1.03
Firmware date: 2121-07-08 16:09
and then to
Thanks in advance
Yes, the SVC code is relevant. If SVC NB52 (look at the sticker underneath the drive), follow the steps in the first post (or the gif), substituting BP50NB40 for WP50NB40. I have pasted them below for you.lokat wrote: ↑Tue Jan 13, 2026 3:45 amHello, also new here.
and after running makeMKV I got the followingI got the All You Need Firmware Pack (MartyMcNuts) packManufacturer: HL-DT-ST
Revision: 1.03
and then to
Thanks in advance![]()
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
After a successful flash to the MK firmware of the drive do the crossflash:
2. Select the RECOVERY option and in the pop up window (as per the window title text), select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed and click OPEN.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 (this is what I recommend) firmware in the normal firmware selection drop box (as per the window title text) then click OPEN.
4. Click START
Thank you !
Followed the process and that was pretty quick
I went with BU40N 1.00 and now makeMKV states that the drive is good
Thanks again for the help. In hindsight it is pretty quick to do
I did try to see if I could read the first UHD BR I had laying around (Ghost in the shell ) but the drive spins for a while and just gives up but works with the regular BR. I guess I will have it to give it another try with another UHD BROS device name: G:
Revision: 1.03
Firmware date: 2120-05-07 09:29
Highest AACS version: 72
Firmware version: 1.03
Just want to confirm -- is flashing of drives on Linux still not working with the latest version(s) of MakeMKV?
I've flashed both ASUS and LG drives on my Linux machine before (June 2024) without issue but was unable to flash a couple Verbatim 43888 drives this weekend. The drive was seen, but any attempt to flash wouldn't produce any output (even with verbose mode) other than saying it was loading the file and then would just stall.
Eventually I just went to my Mac and was able to flash without issue on my MacBook Pro.
You didn't flash it right it's not on bu40n fw you likely need to follow nb52 stepslokat wrote: ↑Tue Jan 13, 2026 4:09 pmThank you !
Revision: 1.03
Yep use older versions. Most go for v1.17.7.taylorwmj wrote: ↑Tue Jan 13, 2026 6:07 pmJust want to confirm -- is flashing of drives on Linux still not working with the latest version(s) of MakeMKV?
ok I got what I did wrongBillycar11 wrote: ↑Tue Jan 13, 2026 11:08 pmYou didn't flash it right it's not on bu40n fw you likely need to follow nb52 stepslokat wrote: ↑Tue Jan 13, 2026 4:09 pmThank you !
Revision: 1.03
The recover action is actually two steps in the SDFtool which I did not see
I recoved to LG BU40N 1.00 and now this drive is showing as such in makemkv
I did try again with Ghost in the shell UHD and it is now recognized and I can explore its content.Drive Information
OS device name: G:
Product: BD-RE BU40N
Revision: 1.00
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Thanks for the help !
Hopefully I wont have to touch this again too soon haha
justlovemovies
Hi all - I've been a lurker on and off for a few years but I'm finally getting around to acquiring drives so I can watch content via a NAS/Plex. Sucks to hear that drives are becoming scarce. I was lucky enough to get my hands on two Pioneer drives that I am looking to flash.
Before I paste the info for both drives, is it fine to run the flash on an Intel Mac that I've installed Windows on via Boot Camp Assist? Thanks!
Absolutely. You don't even have to use Boot Camp. You can freely virtualize Windows on macOS.justlovemovies wrote: ↑Thu Jan 15, 2026 2:02 amis it fine to run the flash on an Intel Mac that I've installed Windows on via Boot Camp Assist? Thanks!
Either way - you're good to go for managing the flashing on a Mac.
Thanks,
Frank
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
justlovemovies
Perfect, thanks Frank!nicholfd wrote: ↑Thu Jan 15, 2026 2:36 amAbsolutely. You don't even have to use Boot Camp. You can freely virtualize Windows on macOS.justlovemovies wrote: ↑Thu Jan 15, 2026 2:02 amis it fine to run the flash on an Intel Mac that I've installed Windows on via Boot Camp Assist? Thanks!
Thanks,
Frank
Sharing the information for both drives below:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: CIDL502520WL
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8511
Firmware version: 1.14
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: TIDL004697UC
Firmware date: 2019-09-05
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.02
PM sent.justlovemovies wrote: ↑Thu Jan 15, 2026 3:19 amPerfect, thanks Frank!nicholfd wrote: ↑Thu Jan 15, 2026 2:36 amAbsolutely. You don't even have to use Boot Camp. You can freely virtualize Windows on macOS.justlovemovies wrote: ↑Thu Jan 15, 2026 2:02 amis it fine to run the flash on an Intel Mac that I've installed Windows on via Boot Camp Assist? Thanks!
Thanks,
Frank
Revision: 1.14
Revision: 1.02
I got ya, I just saw one on eBay was going to buy, but didn't want to jump until I knew. I did pass on it because its location was China, and I don't know what Tarrifs etc would look like LOL!!
