dawn of justice uhd disc
leighdog
Post by leighdog »
MakeMKV v1.18.2 win(x64-release) started
Using LibreDrive mode (v02.1 id=489CDFD6D392)
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?Hds2amKXJd4wSl...
File 00800.mpls was added as title #0
File 00254.mpls was added as title #1
Title #01007.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01117.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01134.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01139.m2ts was added as title #2
Title #01140.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01141.m2ts was added as title #3
File 01142.m2ts was added as title #4
Title #00022.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory H:/
1 titles saved
File 00101.mpls was added as title #0
File 00007.mpls was added as title #1
Title #00008.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.mpls was added as title #2
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00900.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '28778231808'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '28778231808'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '28778231808'
Failed to save title 0 to file H://Batman v Superman- Dawn of Justice- UE_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
was hoping someone could please tell me why i cant get this disc to complete ripping , have cleaned disc , have also copied files from disc to local harddrive & used the same files to attempt to rip in makemkv with the same result , have watched the full disc & the film played fine , i am also using current up to date version of makemkv . thanks
Re: dawn of justice uhd disc
There's a spot on that disc that the optical drive doesn't like.
If cleaning the disc doesn't resolve it, you could try the disc in a different drive if you have access to one.
Regular disc players are setup to plow through spots they can't read and hope you don't notice the resulting glitch. MakeMKV tries to make a perfect copy.
leighdog
Post by leighdog »
hello dcoke22 thanks for ur reply . even when i copied the files from the cd to the local harddrive then got makemkv to make a mkv file from the disc files on my harddrive it still glitched out at the same point of the rip as it did with the disc . its pretty rare i get this type of bug , but it does happen . i got a new disc in the mail yesterday & it worked , totally ripped fine . its like something within the file structure fails & then renders the disc useless with ripping , i dont understand it . thanks
babayaga
Post by babayaga »
leighdog wrote:
Thu Feb 05, 2026 1:18 am
I just started using makemkv til rip uhd discs, and getting many of the same errors as you, my fear is that this is a drive issue that it's not as friendly til uhd as i should like it to be :) these drives wasn't made for 100GB discs, could be the issue, but also strange that you managed to copy all of the files of the disc (from the same drive i presume), to your harddrive without issues! There might be just one thing, someone can correct me here, before i started ripping the disc, i make started scanning it (going through the files errors and so on), i cancled it half through, the i started ripping after that (choosing title, subs audio etc), and when i ripped it, it failed with the error messages you had, 40-50% in the disc, could it be that making a .MKV it has to run through the entire disc scan?
leighdog
Post by leighdog »
hello , yes i used same disc drive . this is a good test to troubleshoot and work out what is faulty and what is causing it all to happen. makemkv will also make a mkv video file from the copy & pasted files from the disc , this test isolates ur ripper drive . this pointed me to some sort of fault within the file structure on the disc , this isnt a rare fault , ive come across a few times now . my belief is that these discs are not perfect they have have glitches & bugs within them sometimes , always start ur troubleshooting with the cheap free & easy stuff 1st , like i do , most stores should always swap the disc over for another , one day i may end up with another ripper drive for a test subject but not atm though . thanks
