arbitrary
Re: SDFtool Flasher
#1561 Post by arbitrary » Fri Jan 09, 2026 10:09 pm
Update: I got it working by using the command line version sdftool.exe only. UI version still doesn't work.
Hi, getting this error window from SDFtool Flasher under Win10 64
Afterwards the tool starts but doesn't list the drives. Any idea how to fix that error?
I have 3 drives in total on SATA. I have flashed 2 before some years ago. Now I am trying to flash the latest one
MakeMkv gives me this drive info:
OS device name: J:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLZN7EI0857
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 82
The (Modified) ASUS ODD FW Changer (24.08.2019) shows the drive and I could try to flash DE_ASUS_BW-16D1HT_3.02.bin.
Should I try that instead of trying to find the fix for SDFtool Flasher ?
RSMegane
Re: SDFtool Flasher
#1562 Post by RSMegane » Sun Jan 11, 2026 5:14 am
Hi team,
I've just purchased MakeMKV, downloaded and registered it. Downloaded SDFtool Flasher.exe and the required Firmware zip. I have read through the guide found here: viewtopic.php?f=16&t=19634 and have a LG WH16NS60 drive (Manufactured: April 2023) with 1.03 firmware.
I made sure this was followed before beginning:
"STOP READ BEFORE FLASHING
IMPORTANT Before you flash:
1. Make sure your Drive was built after 2016 on label or late 2015 if you want to risk it.
2. Drive Platform MT1959<Most important in makemkv
3. SVC NS50+ LG only on label for NB drives NB50+
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
I have tried flashing my drive both using the PowerShell method as demonstrated in the YouTube video in that guide, but also via the SDFtool Flasher.exe method."
The process completes correctly, I do include "enc" in the PowerShell command and check the encrypted box in the SDFtool Flasher.exe, however it does not seem to make any difference to my Firmware version. I am of course choosing the Internal folder and selecting DE_LG_WH16NS60_1.02_MK.bin, but it just doesn't seem to update the Firmware even though it tells me it was successful. I even tried using DE_LG_WH16NS60_1.00.bin, but the same thing happened. It seems to stay on 1.03.
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KL8K76A5953
Firmware date: 2120-05-08 10:10
Highest AACS version: 76
Firmware version: 1.03
Any assistance on getting this resolved would be greatly appreciated.
Thank you.
Re: SDFtool Flasher
#1563 Post by MartyMcNuts » Sun Jan 11, 2026 5:55 am
RSMegane wrote: Sun Jan 11, 2026 5:14 am Hi team,
Revision: 1.03
Thank you.
How is the drive connected?
What OS are you using?
The newer versions of SDFtool flasher don't have a checkbox for encrypted. It sets this automatically. You would just make sure you see a green tick for both MT1959 drive platform and for encrypted firmware.
benraro
Re: SDFtool Flasher
#1564 Post by benraro » Mon Jan 12, 2026 1:06 am
Hello, I'm having trouble understanding which firmware I should use. I get that it's MK version, but I'm unsure which one.
I have the SDFtool, and downloaded the list here: viewtopic.php?f=19&t=19113
Since mine is BU40N with UHD compatible, but made in Taiwan on the back I wasn't sure if I should use: \mk-firmware-pack-20200720\MK\HL-DT-ST\BU40N-R-Tier2-Taiwan\
Or another one. Thank you.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MODPAKB1710
Re: SDFtool Flasher
#1565 Post by MartyMcNuts » Mon Jan 12, 2026 3:13 am
benraro wrote: Mon Jan 12, 2026 1:06 am Hello, I'm having trouble understanding which firmware I should use. I get that it's MK version, but I'm unsure which one.
OS device name: G:
Revision: 1.05
Did you grab my all you need firmware pack from the same place you downloaded the SDFtool Flasher? If so, it has BU40N 1.03-MK in it. Flash this. You can then leave it on BU40N 1.03-MK or you can flash it down to BU40N 1.00 for more UHD software compatability.
Bytez
Re: SDFtool Flasher
#1566 Post by Bytez » Mon Jan 12, 2026 5:06 pm
MartyMcNuts wrote: Wed Jan 07, 2026 11:51 pm
Bytez wrote: Wed Jan 07, 2026 3:01 pm Hello everyone,
I just wanted to double-check.
I have an ASUS BW-16D1HT with firmware 3.11. The guide says I should first upgrade to firmware WH16NS60 1.02-MK and then I can install another firmware (in my case, 3.10 from ASUS).
Is this intermediate step still necessary, or can I go straight to 3.10?
WH16NS60 1.02-MK is recommended as it reads faster and removes the sleep bug. If you don't write discs much, this is the firmware to use. If you do sometimes write to discs, use BW-16D1HT 3.10-MK. You can write directly to 3.10-MK if this is the firmware you want to use.
So the flash wasnt a Problem. But the drive isnt reading anything. (Neither 4K or 1080p). I assume a Hardware Problem but just if you see something wrong here, tell me pls.
Laufwerksinformation
OS-Gerätename: H:
Produzent: HL-DT-ST
Produkt: BD-RE WH16NS60
Revision: 1.02
Serienummer:
Firmware-Datum: 2118-10-29 19:36
Markierungen der Bus-Verschlüsselung: 17
Firmware version: 1.02
Keine Disk eingelegt
Re: SDFtool Flasher
#1567 Post by MartyMcNuts » Mon Jan 12, 2026 10:08 pm
Bytez wrote: Mon Jan 12, 2026 5:06 pm
OS-Gerätename: H:
Produzent: HL-DT-ST
Revision: 1.02
Serienummer:
Did you power cycle the drive after flashing? If installed internally, power off the PC for a few minutes before powering back up.
You say won't read anything. That doesn't tell us much. Do you get errors when ripping or do the discs not even show up in MakeMKV. If errors, clean the disc.
Are you letting the OS initialise the disc before opening the MakeMKV application? If not, you should be.
RSMegane
Re: SDFtool Flasher
#1568 Post by RSMegane » Wed Jan 14, 2026 7:37 am
MartyMcNuts wrote: Sun Jan 11, 2026 5:55 am
Revision: 1.03
Thank you.
Hey MartyMcNuts!
Thank you so much for replying.
It is an internal Sata. Works with CD's and DVD's.
I'm running Windows 11 Pro 25H2 OS Build: 26200.7462
Cheers!
gabbett1
Re: SDFtool Flasher
#1569 Post by gabbett1 » Wed Jan 14, 2026 3:13 pm
Hello, and thank you for the work that you've done. I downloaded the SDFtool Flasher v1.3.6 and tried to flash my drive (LG BP60NB10 (2025 version)). When I tried to do the flash I was given an error from SDFtool.
error:
Command produced error code 0x82052400
Then another window from SDFtool Flasher that states:
Unhandled exception has occurred in your application.  If you click continue, the application will ignore this error and attempt to continue.  If you click quit, the application will close immediately.
Input string was not in a correct format
When I click on details, this is what it says:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
   at System.Number.ThrowOverflowOrFormatException(ParsingStatus status, TypeCode type)
   at System.Convert.ToInt32(String value)
   at SDFtool_Flasher_Updated.Form1.<>c__DisplayClass46_0.<<button_START_Click>b__2>d.MoveNext()
--- End of stack trace from previous location ---
   at System.Threading.Tasks.Task.<>c.<ThrowAsync>b__128_0(Object state)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.6.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
System.Windows.Forms
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
System.Runtime.CompilerServices.Unsafe
    Win32 Version: n/a
    CodeBase:
System.Threading.ThreadPool
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
Any help will be greatly appreciated.
Re: SDFtool Flasher
#1570 Post by MartyMcNuts » Wed Jan 14, 2026 9:09 pm
gabbett1 wrote: Wed Jan 14, 2026 3:13 pm Hello, and thank you for the work that you've done. I downloaded the SDFtool Flasher v1.3.6 and tried to flash my drive (LG BP60NB10 (2025 version)). When I tried to do the flash I was given an error from SDFtool.
error:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Post the MakeMKV drive info and libredrive info sections for the drive.
Re: SDFtool Flasher
#1571 Post by MartyMcNuts » Wed Jan 14, 2026 9:11 pm
RSMegane wrote: Wed Jan 14, 2026 7:37 am
Revision: 1.03
Thank you.
Hey MartyMcNuts!
Cheers!
I know what the model is as it's in the MakeMKV drive info.
So is it installed internally and connected via SATA or externally using something else?
gabbett1
Re: SDFtool Flasher
#1572 Post by gabbett1 » Thu Jan 15, 2026 2:08 am
MartyMcNuts wrote: Wed Jan 14, 2026 9:09 pm
error:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Here's the data you asked for:
Current profile: DVD-ROM
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2121-07-08 15:56
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Re: SDFtool Flasher
#1573 Post by MartyMcNuts » Thu Jan 15, 2026 5:08 am
gabbett1 wrote: Thu Jan 15, 2026 2:08 am
error:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Revision: 1.02
Serial number:
You are using Windows 10/11 64 bit aren't you? I assume you downloaded my all you need firmware pack when you downloaded the SDFtool flasher? You made sure that MakeMKV is installed in the default location (ie: C:\Program Files (x86)\MakeMKV)? You made sure there is no disc in the drive and the tray is closed?
If your drive is SVC NB12 (sticker underneath) you should flash DE_LG_BP60NB10-NB12_1.02-MK. If it is SVC NB10, you should flash DE_LG_BP60NB10_1.02-MK.
RSMegane
Re: SDFtool Flasher
#1574 Post by RSMegane » Thu Jan 15, 2026 6:26 am
MartyMcNuts wrote: Wed Jan 14, 2026 9:11 pm
Hey MartyMcNuts!
Cheers!
It is installed internally and connected via SATA, yes.
cinerama19806
Re: SDFtool Flasher
#1575 Post by cinerama19806 » Thu Jan 15, 2026 10:40 pm
Many thanks for all your efforts here. Hopefully this one's an easy fix and I'm just missing something simple trying to use the SDFtool Flasher. (Side note: I previously successfully flashed an Asus drive but I don't remember when or how, and that drive has pretty much given up the ghost for burning and hasn't successfully opened a 4K disc in ages (lots of grinding) even though it's Libradrive enabled.)
I've now purchased a Verbatim external 4K drive from Amazon (not too many options out there now) which Makemkv is reading as
Revision: 1.05
Serial number: MO6PAKA5435
When I open the SDFtool Flasher for this drive I get the same error previously noted: StartIndex cannot be less than zero (which I believe is not a "show stopper". Once I advance to the software window, I don't see a drive available for flashing (i.e. there's no option available in the pulldown menu for the drive. I don't know if it matters, but I've removed my previous Asus drive as an option and have assigned the new drive the "D" drive letter. (I believe I'm OK with the flash version needed and it's available to me from the "all you need firmware pack" (LG Slim BU40N) - but I can't get there without being able to select a drive.) Please let me know what I'm missing here.
