PM sent.Win1M wrote: Fri Jan 09, 2026 8:13 am Hi Coopervid,
I just bought the following drive and came across the forum. If you could help let me know how to enable UHD on this? Thank you!
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: CIDL502630WL
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
PM sent.Zerocool2040 wrote: Sat Jan 10, 2026 1:27 am Hello
Coppervid
i would love your help with getting this drive flashed
OS device name: G:
Revision: 1.14
Serial number: CIDL504656WL
NegaBBB
Hello Coopervid,
i recently bought this drive and have problems reading UHD disks. I ask you for your help.
Thank you for reading. The drive information is below:
OS device name: E:
Revision: 1.14
Serial number: CJDLxxxxxx
OS device name: E:
Revision: 1.14
ookerberry
Hi @coopervid,
I would also like some help updating the firmware to my UD03 drive please:
Revision: 1.14
Serial number: DGDL54xxxxWL
Highest AACS version: 82
Cheers,
Ookerberry
Revision: 1.14
Cheers,
Ookerberry
Nashorn
Hi Coopervid,
Could you please help me with updating the firmware of my drive?
I really appreciate your help!
Revision: 1.14
Serial number: DEDL XXX
BD raw metadata read: Yes Unrestricted read speed: Yes-
olds216
Could I get some help flashing this drive?
OS device name: E:
Revision: 1.14
Serial number:
Highest AACS version: 76
Pm sent.NegaBBB wrote: Sun Jan 11, 2026 4:22 pm Hello Coopervid,
OS device name: E:
Revision: 1.14
PM sent.ookerberry wrote: Sun Jan 11, 2026 9:09 pm Hi @coopervid,
Revision: 1.14
Cheers,
Ookerberry
PM sent.Nashorn wrote: Sun Jan 11, 2026 11:27 pm Hi Coopervid,
I really appreciate your help!Code: Select all
Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: DEDL XXX Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
PM sent.olds216 wrote: Mon Jan 12, 2026 12:50 am Hi,
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
denniskarlsson
I have this drive. Is it possible to flash it?
OS device name: /dev/sr0
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number:
Firmware date: 2023-04-20
Firmware version: E102/ID26
eblyt
Hi Coopervid,
I need your support for my BDR-UD03
OS device name: E:
Revision: 1.14
Serial number: xxx
Highest AACS version: 60
OS device name: E:
Revision: 1.14
Serial number: xxx
tpferreira
I am at a total loss. I got this drive in the hopes that it could read UHD. Any help would be greatly appreciated.
OS device name: E:
Revision: 1.14
Serial number: DDDL525449WL
OS device name: E:
Revision: 1.14
sure email me that drive info see belowtpferreira wrote: Wed Jan 14, 2026 4:57 am Hi,
OS device name: E:
Revision: 1.14
PM sent.eblyt wrote: Tue Jan 13, 2026 7:21 pm Hi Coopervid,
OS device name: E:
Revision: 1.14
Serial number: xxx
