Chinese Blu-ray drive from AliExpress capable of UHD?
flfreitas
Post by flfreitas »
Hi everyone, I'm new to these forums.
So, recently I found a very cheap Blu-Ray drive in AliExpress that claimed to read/write Blu-Ray. I was skeptical at first, but decided to buy it anyway.
It arrived today, it seems to be totally unbranded, the box only says "Super Slim Drive - Portable USB3.0 interface drive". There's no indication of the company behind it except for the listing of a Shenzhen manufacturer in the barcode. It has a pretty short manual, that has spelling errors, calling it the "SupderDrive", and only mentions DVD playback.\
Nevertheless, it does read blu-rays, I just got it to read some that I own, using VLC + libaacs + KEYDB. It obviously doesn't read UHD ones, but it never claimed to.
When I run makemkv, it hangs when a disc is inserted, but when the tray is empty and closed, makemkv returns the following info:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: GF00
Serial number: [REDACTED]
Firmware date: 2116-12-09 14:58
Bus encryption flags: 1F
So, it seems to be based on the LG BU40N, the odd thing is the revision number GF00, which I've never seen, maybe it means General Firmware? No idea.
Anyway, since it has platform MT1959 and is based on the BU40N, in theory, could LibreDrive work on it? The only reservations I have about flashing it is makemkv hanging when it has a disc, and of course, this weird GF00 version. Has anyone here heard about it?
Re: Chinese Blu-ray drive from AliExpress capable of UHD?
flfreitas wrote: Fri Jan 09, 2026 11:58 pm Hi everyone, I'm new to these forums.
Revision: GF00
So you have tried a UHD disc? If it doesn't read them on the current firmware, you should be able to flash it directly to DE_BU40N_1.00. It will then be able to read UHD discs.
flfreitas
Post by flfreitas »
MartyMcNuts wrote: Sat Jan 10, 2026 12:54 am So you have tried a UHD disc? If it doesn't read them on the current firmware, you should be able to flash it directly to DE_BU40N_1.00. It will then be able to read UHD discs.
Hi, thanks for the reply. Yes, I did try a UHD disc and it doesn't read it. What's the idea behind flashing to a v1.00 firmware? Do old versions of BU40N read UHD? If so, why isn't this the recomended method for this drive?
flfreitas wrote: Sat Jan 10, 2026 1:46 pm
BU40N 1.00 or BU40N 1.03-MK are the recommended firmware versions for the BU40N drive. For UHD discs, the latter firmware only works with MakeMKV and Xreveal while the former firmware is compatible with all good UHD ripping software.
flfreitas
Post by flfreitas »
Hi, I know this thread is dead now. I did not reply earlier because I had to postpone a lot of things because of real life stuff. Anyway, a few months after I asked this, I followed MartyMcNuts' advice and it worked perfectly.
I flashed the BU40N 1.00 firmware and I just successfully backed up the Interstellar 4k blu ray. Thanks a lot! I never expected a Chinese knock-off drive to be able to do this, but since this time I got more than I asked for, I won't complain!
Sorry for the late reply and all the success to you guys!
greyleaf
Post by greyleaf »
flfreitas wrote: Wed Aug 05, 2026 7:42 pm Hi, I know this thread is dead now. I did not reply earlier because I had to postpone a lot of things because of real life stuff. Anyway, a few months after I asked this, I followed MartyMcNuts' advice and it worked perfectly.
Can you provide a link to the drive you bought? I want to buy the same one.
greyleaf wrote: Sat Aug 29, 2026 12:03 am
its not worth the risk get this from a reputable seller
https://www.bhphotovideo.com/c/product/ ... e_usb.html
then get the auto flasher from me or marty
if you dont want to diy flash
