Attempted to use the software on this brand new Blu-ray release (part of the Filmmaker's Signature Series). The disc is seen by the software. Before I attempt to try and rip the largest file I see the following:
MakeMKV v1.7.2 win(x64-release) started
Downloading latest SVQ(s) to C:\Users\Steve/.MakeMKV ...
Loaded 14 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00003.svq
Failed to process BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
BD+ code processed but no FUTs were obtained, errors may follow
File 00850.mpls was added as title #0
Title 00800.mpls is equal to title 00850.mpls and was skipped
Title #00720.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00515.mpls was added as title #1
File 00500.mpls was added as title #2
Title #00002.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.mpls has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00390.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00750.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00514.m2ts was added as title #3
File 00513.m2ts was added as title #4
File 00512.m2ts was added as title #5
File 00511.m2ts was added as title #6
Title #00000.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00510.m2ts was added as title #7
File 00509.m2ts was added as title #8
Title #00301.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00300.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Choosing the one title I get a popup telling me that Copy complete, 0 titles saved, 1 failed.
Interestingly, if I choose all the other titles on the disc, everything works. I'm guessing there's a new BD+ gotcha' on this disc.
p.s. runs find on computer with CyberLink PowerDVD 10 (Win7 64bit)
French Connection - remastered fails
Re: French Connection - remastered fails
Yes, this is new BD+ . Please send bd+ dump per instructions at http://www.makemkv.com/svq/ and SVQ file will be updated.
stevebythebay
Have re-run and sent the dump and log files to the mail address on the page you reference. Thanks for your help.
