Good morning, I wanted to say hello. Please help. I can buy a used Pioneer BDR-S09XLT drive for USD 170. Two purchase offers. One was manufactured in 2018 and the other in 2015. Which one should I choose to work with LibreDrive?
Thank you for your commitment.
Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Szary Kot
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Licensed User MakeMKV
1. Personally, I would not buy a used drive and definitely not at that price!Szary Kot wrote: Thu Jan 08, 2026 10:57 pm Good morning, I wanted to say hello. Please help. I can buy a used Pioneer BDR-S09XLT drive for USD 170. Two purchase offers. One was manufactured in 2018 and the other in 2015. Which one should I choose to work with LibreDrive?
2. Regarding those 2, the manufacture date doesn’t really matter. It’s the date of the current firmware on the drive that matters. You would need the MakeMKV drive info and libredrive info sections to be able to tell if a drive is compatible.
Szary Kot
OK, thanks for the quick reply. I won't buy either of them.
No one is stopping you. If you really need an internal drive, you have little choice these days. Just saying, we need to see the MakeMKV drive info & libredrive info sections before we can say a drive can/will be libredrive compatible.Szary Kot wrote: Fri Jan 09, 2026 8:40 am OK, thanks for the quick reply. I won't buy either of them.
Szary Kot
OK. I'll ask again:
Pioneer BDR-213ULBK, new, firmware 1.02 (unlocked), price $550. Is it worth it?
Only you can determine if it is worth that much. If it is brand new with libredrive enabled, UHD compatible firmware, then maybe.Szary Kot wrote: Sat Jan 10, 2026 12:21 am OK. I'll ask again:
bear7364
I have just found one of these drives in my stash of bits in my loft and thought I would have a try at backing up my 4k disc library. Connected up to pc and ran MKV but have the same issue of not reading the 4k disc.
Any help to resolve would be greatly appreciated if its possible.
Drive info is:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.30
Serial number:
Firmware date: 2014-12-05
Drive platform: RS8600
Firmware version: 1.30/ID43
Drive info is:
OS device name: E:
Revision: 1.30
Serial number:
PM sent.bear7364 wrote: Sat Jan 17, 2026 9:44 pm I have just found one of these drives in my stash of bits in my loft and thought I would have a try at backing up my 4k disc library. Connected up to pc and ran MKV but have the same issue of not reading the 4k disc.
Drive info is:
OS device name: E:
Revision: 1.30
Serial number:
bear7364
Worked a treat @coopervid
Thankyou very much
c0npr
Hi, I recently got a BDR-S09XLB drive (tho the serial does not match the label), here is the drive info:
Can it support UHD? Thanks in advance!
Revision: 1.52
Serial number: ************
Firmware date: 2019-01-11
Drive platform: RS8601
Firmware version: 1.52/ID43
Yes it can do UHD email me that drive info section see below for emailc0npr wrote: Wed Jan 28, 2026 1:04 pm Hi, I recently got a BDR-S09XLB drive (tho the serial does not match the label), here is the drive info:
Can it support UHD? Thanks in advance!Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.52 Serial number: ************ Firmware date: 2019-01-11 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8601 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.52/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
But I do think pioneers sn should match your drive may have been re cased
tommy7600
is there an option to add UHD reader option to 1.55?
Kind regards,
Tom
OS device name: K:
Revision: 1.55
Serial number:OJDL019xxxx
Firmware date: 2023-02-16
Highest AACS version: 76
Firmware version: 1.55/ID43
Unrestricted read speed: YesTom
No, the firmware has been updated and is too new. Must be pre 12/2022.tommy7600 wrote: Fri Jan 30, 2026 3:13 pm Hi,
Kind regards,Code: Select all
OS device name: K: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.55 Serial number:OJDL019xxxx Firmware date: 2023-02-16 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.55/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Tom
longcafe
Hi, I can rip standard blurays but do I need to do something to rip UHD discs? I don't have any right now. Thanks in advance.
Revision: 1.10
Serial number:
Firmware date: 2013-10-15
Highest AACS version: 17
Firmware version: 1.10/ID43
Revision: 1.10
Serial number:
PM sent.longcafe wrote: Tue Feb 03, 2026 5:27 pm Hi, I can rip standard blurays but do I need to do something to rip UHD discs? I don't have any right now. Thanks in advance.
Revision: 1.10
Serial number:
