Pioneer BDR-208D
danieduardo88
Pioneer BDR-208D
Hey,
I saw these drives could possibly be flashed for UHD Blu-ray ripping in the makemkv forms. I have a BU40N, but even after cleaning it stopped reading blu-rays in general. I remembered I had the BDR-208D laying around and it works perfectly(used a handful of times). So is it possible for 4K Blu-rays? Here are the specs from makemkv:
Manufacture date: March 2013
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: XXXXXXXXXXXX
Firmware date: 2012-08-22
Bus encryption flags: 13
Highest AACS version: 38
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
OS device name: E:
Revision: 1.10
Re: Pioneer BDR-208D
Billy will take care of you as you emailed him already.danieduardo88 wrote: Thu Jan 08, 2026 12:13 pm Hey,
OS device name: E:
Revision: 1.10
tootall44
I also Have a pioneer bdr-208d hoping to flash it Drive Information
OS device name: F:
Revision: 1.10
Serial number: MGDL072068WL
Highest AACS version: 66
Pioneer bdr-208d
OS device name: F:
Revision: 1.10
Pioneer bdr-208d
PM sent.tootall44 wrote: Sat Jan 31, 2026 1:33 am I also Have a pioneer bdr-208d hoping to flash it Drive Information
OS device name: F:
Revision: 1.10
Pioneer bdr-208d
updir2
Hi Coopervid,
I have a BDR-S08 that has the same drive platform and firmware name according to the LibreDrive Information:
OS device name: E:
Product: BD-RW BDR-S08
Revision: 1.10
Serial number: MGDL006836WL
Firmware date: 2012-08-28
Highest AACS version: 61
Firmware version: 1.10/ID43
Is it also possible to patch this drive to enable reading UHD discs?
OS device name: E:
Revision: 1.10
PM sent.updir2 wrote: Thu Feb 26, 2026 1:30 pm Hi Coopervid,
OS device name: E:
Revision: 1.10
updir2
Thanks, that worked perfectly.
spyckoo
hi, can someone please PM me what I need to flash my BDR-208D to rip UHD? Thanks!
Informations lecteur
Nom du lecteur SE : F:
Fabricant : PIONEER
Produit : BD-RW BDR-208D
Révision : 1.10
Numéro de série :
Date micrologiciel : 2012-08-22
Marqueurs d'encryptage bus : 13
Version AACS la plus haute : 76
Fabricant : PIONEER
Révision : 1.10
Numéro de série :
PM sent.spyckoo wrote: Sun Apr 12, 2026 3:50 pm hi, can someone please PM me what I need to flash my BDR-208D to rip UHD? Thanks!
Fabricant : PIONEER
Révision : 1.10
Numéro de série :
sure email me that info and all others email me no need to post your info here just reach out to me directlyspyckoo wrote: Sun Apr 12, 2026 3:50 pm hi, can someone please PM me what I need to flash my BDR-208D to rip UHD? Thanks!
Fabricant : PIONEER
Révision : 1.10
Numéro de série :
see below for email
spyckoo
Thanks very much!Coopervid wrote: Sun Apr 12, 2026 5:00 pmPM sent.spyckoo wrote: Sun Apr 12, 2026 3:50 pm hi, can someone please PM me what I need to flash my BDR-208D to rip UHD? Thanks!
Fabricant : PIONEER
Révision : 1.10
Numéro de série :
DrTek
Re: Pioneer BDR-208D (RS8301)
I found an old 209 that had never been used.
It will rip regular BD's but would like to be able to rip 4k BD's as well.
Suggestions?
Thanks.
Product: BD-RW BDR-208M
Revision: 1.50
Firmware date: 2015-09-24
Highest AACS version: 19
Firmware version: 1.50/ID60
Suggestions?
Thanks.
Revision: 1.50
sure email me that info and all others email me no need to post your info here just reach out to me directlyDrTek wrote: Fri May 01, 2026 8:00 pm I found an old 209 that had never been used.
Suggestions?
Thanks.
Revision: 1.50
see below for email
sirius
Hi, I also have a DBR-208DBK.
This is the data I’m getting:
Información de unidad de disco
Nombre del SO del dispositivo: J:
Perfil actual: BD-ROM
Fabricante: PIONEER
Producto: BD-RW BDR-208D
Revisión: 1.10
Número de serie: LIDL006414WL
Fecha del firmware: 2012-08-22
Marcas de cifrado bus: 13
Highest AACS version: 10
I would appreciate any help you could provide; thanks.
Fabricante: PIONEER
Revisión: 1.10
see guide below if you email me you will get a reply in 5 minssirius wrote: Fri Oct 16, 2026 5:18 am Hi, I also have a DBR-208DBK.
Fabricante: PIONEER
Revisión: 1.10
