email me that drive info see belowspeerk30 wrote: Sat Jan 03, 2026 1:14 am Drive Information
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: XXXXXXXXXX
Firmware date: 2020-07-21
Firmware version: ID76
A friend of mine picked me up this over the holidays, because I built a NAS, and he mentioned running Jellyfin off it. That I could use this to rip my Blu-ray TV/Movie collection for streaming if I flashed it, and used MakeMKV. I'm new to this, and wasn't sure what to flash? All my 4k & regular blu-ray discs are bought in the US, so not sure if region matters.
My friend said he tried to get the Asus BW-16D1HT, but was out of stock so he got this. I waasn't sure looking at the all you need firmware pack if that Asus BW-16D1HT firmware works for this model too? Apologies if silly questions.
Pioneer RS8F00
Re: Pioneer RS8F00
beust
Re: Pioneer RS8F00
Hi cooper !
Can I have the PM too please ?
Thank you
Thank you
beust wrote: Fri Dec 26, 2025 4:35 pm Hi !
I also have an ASUS BW-16D1H-U PRO, but the Drive platform is listed as a: Pioneer RS8F00. Here are the specs
Informations lecteur
Nom du lecteur SE : F:
Profil actuel : BD-R SRM
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : ************
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 75
Drive platform: RS8F00
Firmware version: E116/ID71
I take any help to read UHD on it
thanks a lot in advance !![]()
Re: Pioneer RS8F00
PM is coming.beust wrote: Mon Jan 05, 2026 11:48 am Hi cooper !
Thank you
Fabricant : ASUS
Révision : E116
scrunch.9s
Re: Pioneer RS8F00
Can i have the PM too please
Re: Pioneer RS8F00
I suspect you'll need to provide the information on your drive, first... Not all drives can be side-grated.
scrunch.9s
Re: Pioneer RS8F00
Ah yes. Here it is:
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer:
Firmware-Datum: 2020-07-21
Highest AACS version: 78
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer:
Re: Pioneer RS8F00
Sure! I can send you a PM. A recipe for eggs and bacon?
scrunch.9s
Re: Pioneer RS8F00
What do you mean ? For others PM is coming ? What did i say wrong
guitarphreak
Re: Pioneer RS8F00
Hello. I had a look at the documentation in viewtopic.php?f=16&t=19634 but was not able to find anything specific for the BW-16DX1-U with Pioneer RS8F00. I got this drive recently, so trying to do the due diligence so I don't brick it
I'm wondering if there's anything I'm missing? I saw read about the sidegrade but everything seems to be written for the 16D1HT, so wanted to check with people that have successfully flashed drives similar to mine? I see users posting their drive info, so here's mine:
Thanks in advance for any info!
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
No disc inserted-
Re: Pioneer RS8F00
Well, you are asking for a PM for what exactly? You didn't copy and paste your MakeMKV drive info and libredrive info sections, so nobody knows what you want.scrunch.9s wrote: Mon Jan 05, 2026 8:24 pm What do you mean ? For others PM is coming ? What did i say wrong
scrunch.9s
Re: Pioneer RS8F00
I posted them and didn't notice that they hadn't been posted yet. They still had to be approved by an admin. If you look now, my info is before the bacon post. It was bad timing.MartyMcNuts wrote: Tue Jan 06, 2026 2:05 amWell, you are asking for a PM for what exactly? You didn't copy and paste your MakeMKV drive info and libredrive info sections, so nobody knows what you want.scrunch.9s wrote: Mon Jan 05, 2026 8:24 pm What do you mean ? For others PM is coming ? What did i say wrong
scrunch.9s
Re: Pioneer RS8F00
Is it possible to flash the drive for UHD?scrunch.9s wrote: Mon Jan 05, 2026 6:21 pm Ah yes. Here it is:
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E116
Serienummer:
Re: Pioneer RS8F00
This is what you said wrong. A useless post w/o any information which ticks me off. Same as the guys who want new keys when the keys are already in the keydb.cfg. And remember: You have no right to get this. So be a bit more friendly and humble. PM is coming.
Re: Pioneer RS8F00
PM sent.guitarphreak wrote: Tue Jan 06, 2026 12:26 am Hello. I had a look at the documentation in viewtopic.php?f=16&t=19634 but was not able to find anything specific for the BW-16DX1-U with Pioneer RS8F00. I got this drive recently, so trying to do the due diligence so I don't brick it
Thanks in advance for any info!Code: Select all
Drive Information OS device name: F: Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76 No disc inserted![]()
DarkLucy
Re: Pioneer RS8F00
Hello, I am new on this stuff. I have a drive that cannot read UHD.
Informations:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: XXXX
Highest AACS version: 75
Possible that this drive can be flashed to 4kUHD?
I have read a bit through the forum but I want to be 100% sure, that I doing things correctly if I would go the flashing way.
I appreciate every help thanks
Informations:
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: XXXX
