I'm running MBP 2.4Ghz w/ OS 10.5.8 w/ 4GBs of RAM and MakeMKV 1.4.8. w/LG WH08LS20 Blu-Ray Burner.
Fairly new to ripping blu-rays but have used this great program to rip several of my blu-rays so far: X-Men Origins Wolverine, GI Joe, Taking of Pelham 123 and Star Trek (2009).
Tried ripping Indiana Jones 4 and it's failing to complete the process and erroring out at the end giving "0 completed, 1 failed". Tried cleaning the disk, restarting and trying again but to no avail. I'm able to rip this blu-ray w/another program and play the disc on my PS3.
Here is the log, any help would be appreciated. Thanks.
MakeMKV v1.4.8 beta darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/klandragon/MakeMKV_log.txt
FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
LIBMKV_TRACE: No CC5 in 00030
LIBMKV_TRACE: No CC5 in 00031
LIBMKV_TRACE: No CC5 in 00032
LIBMKV_TRACE: No CC5 in 00033
Only extracting AC3 core audio from stream #2 of type 'DD True HD audio' in file 00009.m2ts
File 00000.mpls was added as title #0
LIBMKV_TRACE: No CC5 in 00034
LIBMKV_TRACE: No CC5 in 00213
Title #00007.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
LIBMKV_TRACE: No CC5 in 00012
LIBMKV_TRACE: No CC5 in 00300
Title #00230.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00232.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00234.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00235.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00236.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00237.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00238.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00239.mpls has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00240.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00241.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00242.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00243.mpls has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00244.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
LIBMKV_TRACE: No CC5 in 00301
LIBMKV_TRACE: No CC5 in 00302
LIBMKV_TRACE: No CC5 in 00304
LIBMKV_TRACE: No CC5 in 00305
LIBMKV_TRACE: No CC5 in 00306
LIBMKV_TRACE: No CC5 in 00307
LIBMKV_TRACE: No CC5 in 00400
LIBMKV_TRACE: No CC5 in 00401
LIBMKV_TRACE: No CC5 in 00402
LIBMKV_TRACE: No CC5 in 00403
LIBMKV_TRACE: No CC5 in 00404
LIBMKV_TRACE: No CC5 in 00416
LIBMKV_TRACE: No CC5 in 00407
LIBMKV_TRACE: No CC5 in 00409
LIBMKV_TRACE: No CC5 in 00410
LIBMKV_TRACE: No CC5 in 00411
LIBMKV_TRACE: No CC5 in 00412
LIBMKV_TRACE: No CC5 in 00413
LIBMKV_TRACE: No CC5 in 00414
LIBMKV_TRACE: No CC5 in 00415
LIBMKV_TRACE: No CC5 in 00417
LIBMKV_TRACE: No CC5 in 00303
Title #00004.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #1
File 00013.m2ts was added as title #2
Title #00014.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory /Volumes/50CalAL_BD_RIPS/Movies
FAILURE: Code 4294967276 at @5_r6=!rR4?0;u;":121267270
FAILURE: Code 0 at [iead6MKH~pEx6+G,Ifo:213130651
FAILURE: Code 0 at )MSesRdk.'R(!BY%]w<E:121262164
FAILURE: Code 8321728 at )MSesRdk.'R(!BY%]w<E:213129639
Failed to save title 0 to file /Volumes/50CalAL_BD_RIPS/Movies/title00.mkv
0 titles saved, 1 failed
Problems Ripping Indiana Jones 4 Blu-Ray
Re: Problems Ripping Indiana Jones 4 Blu-Ray
The log file saved in your home directory, the "/Users/klandragon/MakeMKV_log.txt" - does it have any lines that look like "SD=blablabla"? Please provide the full log or at least just these lines. The program overwrites the log each time it starts so you might have to redo the disc. Sorry, and thanks for reporting.
50CalAL
Hi Mike,
The paste above was the entire log from "/Users/klandragon/MakeMKV_log.txt" directly after the attempt to rip this movie.
