Question ugreen usb sata adapter
itoman
#1 Post by itoman » Tue Jan 06, 2026 4:05 pm
It's not specified in the product manual or box, but does the Ugreen SATA/USB adapter, Model: CM257 – 60561, use the ASM1153 or ASM225CM chip? Does this adapter support, or not fully support, the ASUS 5.25" SATA DVD drive?
Re: Question ugreen usb sata adapter
#2 Post by Billycar11 » Tue Jan 06, 2026 6:25 pm
It likely won't work as it has no sata power see guide below for adapters and cases that work.
itoman
#3 Post by itoman » Tue Jan 06, 2026 11:00 pm
#4 Post by MartyMcNuts » Tue Jan 06, 2026 11:18 pm
How about you just get one of the models known to work??
Fideco:
https://www.amazon.com.au/Adapter-FIDEC ... r=1-4&th=1
Alxum:
https://www.amazon.com.au/Alxum-Adapter ... 554&sr=1-3
itoman
#5 Post by itoman » Wed Jan 07, 2026 12:54 pm
Those adapters you mentioned are very expensive. I don't use any IDE drives; I only use HDDs and a 5.25" ASUS SATA DVD drive.
#6 Post by Billycar11 » Wed Jan 07, 2026 12:57 pm
We have given you the options we know work you can buy whatever you want and if it works report it in the guide with a link to it and I will add it to the list of know working ones
No one else is going to be able to help you we bought all these adapters and found what ones work
itoman
#7 Post by itoman » Wed Jan 07, 2026 1:12 pm
what cheap models seller in aliexpress are good and works with dvd drives sata 5,25"?
#8 Post by Billycar11 » Wed Jan 07, 2026 1:32 pm
We don't know I told you there is a $16 one in the guide that's cheap enough
Stop asking and you tell us what one works
