Fresh of the boat season two all disks unreadable?
mtrcycllvr
Post by mtrcycllvr »
Hello! Trying to archive "fresh off the boat" season two. These DVD disks appear to be recordable media and all three disks show similar symptoms:
udf: udf_get_node: bad allocation extension size in udf_node
DEBUG: Code 0 at :"jonv"P\@y9NM7G&:213130283
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 236 at r8+;sI&bXH(5!l:121273020
Calculated BUP offset for VTS #3 does not match one in IFO header.
DEBUG: Code 2 at r8+;sI&bXH(5!l:213131755
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
DEBUG: Code 10 at {WOf^PqOTlWjI_,n2:213131318
DBG ASSERT: V];kt6:Z3eLsEu} 3+Fs-d6-w>Wo!-fx[lQ at r8+;sI&bXH(5!l:29402003
Calculated BUP offset for VTS #10 does not match one in IFO header.
DEBUG: Code 118095996 at ZO*-W@C?$mpqYG;MnHB.Srv:29394183
DEBUG: Code 0 at ZO*-W@C?$mpqYG;MnHB.Srv:121263590
DEBUG: Code 0 at 0WlR+T>f@FT?Zj*w,Uaf:29394689
MakeMKV then just sits forever with the timers running, but nothing happening. I've tried just extracting the entire disk as ISO, and reading the disk to try and extract separate titles, but both methods result in the output as shown. I use the same hardware and readers to archive other titles, so I am confident in my hardware working.
MakeMKV v1.18.2 darwin(arm64-release) started - Mac Studio, external DVD/Bluray drive(s).
It should ALSO be mentioned that dvdplayer.app plays the disks just fine..
Any thoughts on what I might be encountering here? Thanks so much for everyone's time and effort.
bdc_dtm
Re: Fresh of the boat season two all disks unreadable?
Post by bdc_dtm »
I had a similar problem. I noticed the DVD's themselves had a bluish hue to them, and had really low quality menu's. Since the website foxconnect com was listed on the dvd's, that leads me to believe that Fox wasn't really making DVD's.
They outsourced it to an on-demand ripper service that did a pretty shoddy job.
