Puss in Boots error
hsu4186
Puss in Boots error
Post by hsu4186 » Sat Mar 10, 2012 5:37 pm
I'm getting an odd error message when trying to convert Puss in Boots to mkv. I've attached a screen shot to illustrate both the error and the convert screen.
Any help would be appreciated.
crowfax
Re: Puss in Boots error
Post by crowfax » Sat Mar 10, 2012 6:05 pm
Your drive can not read the disc.
This is not a copy protection issue.
There is no copy protection that can stop a drive reading a disc.
Return the disc for a new one, it is damaged / poorly manufactured.
setarip_old
Post by setarip_old » Sat Mar 10, 2012 6:17 pm
@hsu4186
Hi!
You might want to try carefully and thoroughly cleaning the disc before you consider returning it for an exchange...
hsu4186
Post by hsu4186 » Sat Mar 10, 2012 10:51 pm
Thanks. Thanks was it. The BD had a scratch on it. Thanks again.
