I'm getting an odd error message when trying to convert Puss in Boots to mkv. I've attached a screen shot to illustrate both the error and the convert screen.
Any help would be appreciated.
Puss in Boots error
Puss in Boots error
- pussinboots.png (51.43 KiB) Viewed 10738 times
Re: Puss in Boots error
Your drive can not read the disc.
This is not a copy protection issue.
There is no copy protection that can stop a drive reading a disc.
Return the disc for a new one, it is damaged / poorly manufactured.
setarip_old
@hsu4186
Hi!
You might want to try carefully and thoroughly cleaning the disc before you consider returning it for an exchange...
Hi!
Thanks. Thanks was it. The BD had a scratch on it. Thanks again.
