Latest MakeMKV cannot see Samsung SE-506 drive
Roy_Boy_60
Post by Roy_Boy_60 »
I am running Sonoma 14.7.4 on an M1 MacBook Air. I downloaded the lastest 1.18.2 MakeMKV. It no longer is able to see my USB-connected Samsung SE-506 external Blu-ray drive. I had no issues with this in the prior MakeMKV version. I do have a dual USB-C hub that provides the USB-A ports. This all did work previously. Any thoughts on what the issue might be? Thanks
Re: Latest MakeMKV cannot see Samsung SE-506 drive
What things changed? Just the version of MakeMKV? What version were you using before?
Is the USB-C hub new?
If you put a disc in the drive, does it mount in Finder?
As a side note, I doubt it matters for MakeMKV but the most recent version of Sonoma is 14.8.3. It seems odd to me to be on Sonoma 14.7.4. :) For that matter, why be on Sonoma at all? I understand why you might not want to upgrade to macOS 26 Tahoe, but macOS 15 Sequoia is perfectly fine. 15.7.3 is the most recent version of Sequoia. (How to download and install macOS)
Roy_Boy_60
Nothing changed in my setup. I did load a blu-ray that I had previously ripped and it did not get recognized by either finder or MakeMKV. I did just order a new Anker usb-c hub to see if there is some issue with my current one.
Roy_Boy_60
I found out that my older usb-c hub had ports that failed. The new Anker hub fixed the issue and ripping Songs From the Big Chair now. :D
