Question ugreen usb sata adapter
itoman
It's not specified in the product manual or box, but does the Ugreen SATA/USB adapter, Model: CM257 – 60561, use the ASM1153 or ASM225CM chip? Does this adapter support, or not fully support, the ASUS 5.25" SATA DVD drive?
Re: Question ugreen usb sata adapter
It likely won't work as it has no sata power see guide below for adapters and cases that work.
How about you just get one of the models known to work??
Fideco:
https://www.amazon.com.au/Adapter-FIDEC ... r=1-4&th=1
Alxum:
https://www.amazon.com.au/Alxum-Adapter ... 554&sr=1-3
itoman
Those adapters you mentioned are very expensive. I don't use any IDE drives; I only use HDDs and a 5.25" ASUS SATA DVD drive.
We have given you the options we know work you can buy whatever you want and if it works report it in the guide with a link to it and I will add it to the list of know working onesitoman wrote: Wed Jan 07, 2026 12:54 pm Those adapters you mentioned are very expensive. I don't use any IDE drives; I only use HDDs and a 5.25" ASUS SATA DVD drive.
No one else is going to be able to help you we bought all these adapters and found what ones work
itoman
what cheap models seller in aliexpress are good and works with dvd drives sata 5,25"?
We don't know I told you there is a $16 one in the guide that's cheap enoughitoman wrote: Wed Jan 07, 2026 1:12 pm what cheap models seller in aliexpress are good and works with dvd drives sata 5,25"?
Stop asking and you tell us what one works
