Help with a Pioneer BDR-UD02
redrok84
Post by redrok84 »
Maybe a long shot, but looking to see if this drive could be firmware flashed / enabled for UHD:
Manufacturer: PIONEER
Product: BD-RW BDR-UD02 (shows BDR-UD02VA on the drive)
Revision: 1.00
Serial number: ***
Firmware date: 2012-10-18
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8410
Firmware name: PIONEER BDR-US02
Firmware version: 1.00/ID01
Thanks for any help!
Re: Help with a Pioneer BDR-UD02
redrok84 wrote: Sun Jan 04, 2026 7:10 am Maybe a long shot, but looking to see if this drive could be firmware flashed / enabled for UHD:
Revision: 1.00
Serial number: ***
Libredrive is enabled, so is good for Blu-ray Discs but I think it might be too old for cross-flashing for UHD.
Revision: 1.00
Serial number: ***
Crossflashing is not possible for this drive.
redrok84
Post by redrok84 »
Thanks for the updates! Will move toward purchasing a new drive.
Yethidran
Post by Yethidran »
hi redrok84, i wonder if you still have your UD02 with you? i have a UD02 also, but i didnt back up the original firmware before proceeding to crossflash it to a UD03 and then eventually to a UD04...now its a dead drive as the laserhead mechanism is stuck at the extreme opposite end instead of being positioned next to the central spindle where it should always be positioned to read discs..
if you still have your ud02, i would definitely be grateful if i could get the original ud02 firmware to bring back to live my dead ud02. thanks.
Revision: 1.00
Serial number: ***
Would you be willing to backup your UD02 firmware and upload it to say Google drive? Your firmware could then be used to rescue misflashed UD02 drives. A new free firmware flasher is avaialble since a couple of days. Just need to know on which OS you are.
Yethidran
Post by Yethidran »
Thanks Coopervid for chipping in to help. Greatly appreciated. Hopefully Redrok84 sees this to help us all out.. (those with a UD02 Drive)
mattjackson86
Post by mattjackson86 »
gwhitcombe71
Post by gwhitcombe71 »
always dump teh original firmware first, learnt that the hard way on an old LG...
