Matrix from 1999 won't copy
Wally
Post by Wally »
I have been trying to copy the Matrix from 1999 and I get the following error.
MakeMKV v1.17.6 win(x64-release) started
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The Disk plays normally and has no scratches.
Re: Matrix from 1999 won't copy
Post by d00zah »
Wally wrote:
Thu Feb 22, 2024 7:08 pm
Well, "Auto" didn't cut it. Try one of these (CellTrim?):
DVD opening modes - CellWalk, CellTrim, CellFull
pccousins
Post by pccousins »
I am having the same issue as the original post. I tried opening the dvd manually and saving title 1 (which VLC tells me is the correct title). The file saves successfully, BUT the first 2.5-3 mins are cut off (the opening credits and Trinity's initial skirmish with the agents). I have not been able to find anything in the forums that would correct the issue of MakeMKV cutting off these minutes of a show. Thoughts?
postal_24
Post by postal_24 »
Had same kind of problem here with getting it ripped from my disc, and when I finally did get it ripped, it started several minutes into the movie.
Eventually I found that using "CellFull" worked to expose more. Once that brought up the list of media to rip, check carefully for a slightly bigger file among the mess of junk that shows up in the list. I found a slightly bigger file that was the correct one to rip and that worked.
I had two copies of Matrix 1 actually and both exhibit these symptoms (bought at different times so I doubt they are the same "run" of the movie).
There is something going on with this movie and others like the move "300" (also from WB...). I have same issue with 300 but haven't worked out how to solve that one yet. Maybe it's a WB DVD thing?
IronRod
Post by IronRod »
Same issue. I have the "4-film Collection" produced in 2003 and while I can rip "Matrix Reloaded" and "Matrix Revolutions", it fails to auto rip "The Matrix". Using CellFull, I had the same experience as @postal_24 and can play "The Matrix" without error using VLC (which is using libmmbd).
I ran into something similar (a few years back) when I ripped the P90X discs and had to do that manually. So, I tried opening it in manual mode (still with CellFull) and this time I found that track 4 was the full movie and was able to rip it successfully. Note that I didn't do anything like one has to usually do when doing manual mode (e.g., pasting in the codes) so, maybe I just didn't see this one last time. Not sure. All I know is the second time it ripped successfully.
mikejsc
Post by mikejsc »
Thank you for posting this. I never would've figured out how to copy this. "CellFull" worked to give me a complete version and one with the opening missing until Trinity call Morpheus. I discovered the complete version contained 99 Chapters. The incomplete one was 37 chapters. Google tells me versions vary between 38 and 39 chapters depending on the disc one has. So, I took this a step further. I discovered the first six chapters of the complete version contained the missing video from the 37 chapter version. I used MKVToolNix Multiplexer to split the complete version at the end timestamp for chapter six. Using this new file that contains the part missing from the 37 chapter version, I used Chapter Editor to change the end timestamp for Chapter 01 to the timestamp at the end of Chapter 06. I renamed this new Chapter 01 to Chapter 00 and removed the last five chapters and saved that file. I took this file and added it to Multiplexer then appended the 37 Chapter version to it. Finally, I renamed the now 38 Chapters in the formerly incomplete version of the video from Chapter 00 to Chapter 37 to Chapter 01 to Chapter 38. Now I have a complete version without any funkingness of 99 chapters and chapters numbered conventionally from 01 to 38. I'm not sure all of that is necessary, but it was a good exercise in learning what one can do with MKVToolNix.
