Maybe a long shot, but looking to see if this drive could be firmware flashed / enabled for UHD:
Manufacturer: PIONEER
Product: BD-RW BDR-UD02 (shows BDR-UD02VA on the drive)
Revision: 1.00
Serial number: ***
Firmware date: 2012-10-18
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8410
Firmware name: PIONEER BDR-US02
Firmware version: 1.00/ID01
Thanks for any help!
Help with a Pioneer BDR-UD02
Re: Help with a Pioneer BDR-UD02
Libredrive is enabled, so is good for Blu-ray Discs but I think it might be too old for cross-flashing for UHD.redrok84 wrote: Sun Jan 04, 2026 7:10 am Maybe a long shot, but looking to see if this drive could be firmware flashed / enabled for UHD:
Revision: 1.00
Serial number: ***
Crossflashing is not possible for this drive.redrok84 wrote: Sun Jan 04, 2026 7:10 am Maybe a long shot, but looking to see if this drive could be firmware flashed / enabled for UHD:
Revision: 1.00
Serial number: ***
redrok84
Thanks for the updates! Will move toward purchasing a new drive.
